Robert1969
Topic: Antenna Boost Issue Posted: 03 Dec 2017 at 11:31pm |
Originally posted by mcarter
THANKS David, I found a replacement for the wall plate, no OEM but looks exactly the same. I don't think it is a Winegard part. God Bless FR. I can run the whole RV on back wards engineering, but sometimes I actually like to fix something. Not sure what a signal strength meter would buy me with these simple batwings. |
Hello Mike old post sorry. What part did you get? Mine when out today. Bought a Winegard rv-7542 on Amazon but not sure if it’s the right one. Just curious what you got.
Bugout
Posted: 24 Jul 2017 at 1:39pm |
I like the toothpick plan
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
Posted: 23 Jul 2017 at 5:47pm |
Guests
Posted: 23 Jul 2017 at 5:25pm |
My best guess would be a faulty switch. Unless you want to try to "MacGuyver" a fix, then my other best guess that it is a Winegard part.
Awhile back I saw one with a built in signal strength meter, which I thought would be nice - should I ever need to replace mine.
Posted: 23 Jul 2017 at 3:53pm |
Working an issue that started today. When using my television antenna and enabling the amp - when I push in small button on that turns boost in, it lights and when I released it the light goes off, it doesn't stay on. I have verified when the light is on the boost is on and the antenna is working. I get tele signal. As long as I hold the button on - the boost is working. I pegged the button down with a toothpick and the amp works and I get reception, release the button and - no boost - the power goes off. My assumption is the antenna and the boost is working. The switch is NOT. There is no loss of 12V. As long as the switch is forced closed. I can either replace switch or buy a large amount of toothpicks. My first question is - is that a Winegard plate or is it another make? I have the old style "Batwing" antenna. THANKS.
