HavaPod
Topic: Tire lugnuts & air pressure Posted: 08 Jul 2017 at 12:32pm |
Steve and Peggy Thorndill
HavaPod
2013 R-Pod 177
Tacoma, WA
HavaPod
Posted: 08 Jul 2017 at 12:39pm |
meant to add......
our Rpod has the big wheels and the lug nuts (Hood River edition) that a my normal lugnut wrench with 19 and 21 mm setting doesn't quite work. 19 is too small and 21 is too large. Went to an auto store to see if they had a 20 mm and they did not. Any suggestions on how to get a snug fit or where to go to get the right size. Also, what should the normal tire pressure be for these big tires? Thanks for any help you can provide.
HavaPod
2013 R-Pod 177
Tacoma, WA
funks
Posted: 08 Jul 2017 at 1:13pm |
I use a 13/16 on my 2014 179 Give it a try good luck John
Posted: 08 Jul 2017 at 2:18pm |
Made in America. English sizes.
Posted: 08 Jul 2017 at 3:46pm |
Cold tire pressure should be listed on tire. Fill to that pressure - COLD.
Bugout
Posted: 09 Jul 2017 at 9:53am |
I think the lug nut is 11/16 just like the 4 corner jacks
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
Posted: 09 Jul 2017 at 10:56am |
Originally posted by Bugout
I think the lug nut is 11/16 just like the 4 corner jacks |
11/16 would be around 17-1/2 mm. Our stabilizers use 3/4", and I remember using the 3/4" socket on the spare tire nuts. IDNR what I used on the lug nuts.
Bugout
Posted: 09 Jul 2017 at 12:57pm |
Gluyguy you are right went over to the pod to check lug nuts 3/4 but my jacks are 11/16 that's the largest socket in the set I use with camper and my drill.more then likely different jacks. Let no two pods be the same.
Posted: 09 Jul 2017 at 7:08pm |
We measure the same as GlueGuy, 3/4" on both stabilizers and lug nuts. But then again our pod dates back to 2011.
HavaPod
Posted: 15 Jul 2017 at 2:12pm |
Thanks everyone for your comments!
HavaPod
2013 R-Pod 177
Tacoma, WA
