Kris B
Joined: 04 Jul 2017 Location: Ivins UT Online Status: Offline Posts: 9 |
Calendar Event: Putting onR-pod coverPosted: 05 Jul 2017 at 1:22pm |
Okay, so I bought a 2013 R-176 and am trying to put the cover on – it’s 100+ degrees here and I won’t be camping for a couple months. Any suggestions how one person can put the cover on??? I’ve spent 1-1/2 hours and finally got it half on, only to have it hang up on the AC/TV antenna. Help! |
Kris Brown
rda54
Joined: 18 Nov 2016 Location: Minnesota Online Status: Offline Posts: 106 |
Posted: 05 Jul 2017 at 8:50pm |
I put a rope on the Velcro on the back and throw the rope over the camper and pull it up to the a.c. and antenna then get on a ladder and get it over them then pull it the rest of the way.
Ronald & Lonna
2014 178 2016 Chevy 1500 |
Posted: 06 Jul 2017 at 7:12am |
Method 1: Lay it flat. Roll both sides to the middle. then you have a long, skinny (relatively) bundle. Tie a rope to pull it up over, then get a ladder and unroll the sides.
Method 2: This starts the same as method 1 by rolling the sides. Then roll from the ends to the middle. Use a ladder and carry this bundle up to the top and unroll it toward the front and back, then unroll the sides. Method 3: Lay the cover on the ground spread out with the front toward the trailer's front and the back stretched out away from the trailer. Take two poles and attach one to each of the back corners. With another person helping, lift the cover over the top of the 'Pod. I'm sure there are other methods as well. Find one that works for you. I find method 2 works best for me if I have to do it alone. Method 3 is better if you have help. |
Kris B
Posted: 06 Jul 2017 at 1:09pm |
Thanks ! I'll try that!
Kris Brown
Steve 911
Joined: 09 Sep 2016 Location: Northern Ca. Online Status: Offline Posts: 92 |
Posted: 18 Jul 2017 at 12:30am |
X2 on method #2
Firefighter Steve (retired)
2017.5 Rpod 179 (Reepod) 2016 Highlander AWD w/tow pkg. E2 wdh, prodigy RF brake controller. |
Subzilla
Joined: 23 Jan 2017 Location: Concord, NC Online Status: Offline Posts: 302 |
Posted: 18 Jul 2017 at 10:38am |
Stephen's method 2 is what I do. Couldn't see dragging it over the items on top including the television antenna.
Mark
Kris B
Posted: 18 Jul 2017 at 11:47am |
Thanks! one more quick question. My TV antenna (nonretractible), the front arm points straight up and the back arm points backward at a 45-degree angle. Is this how they're supposed to be ?? It gets good reception.
Kris Brown
Weekend Warrior
Joined: 05 Nov 2016 Online Status: Offline Posts: 35 |
Posted: 27 Jul 2017 at 3:11pm |
The easiest method is a 2 person procedure. Get two long broom handles. Lay the cover on the ground inside out. (reversed). Start at front by placing the broom handles into the front corner area. Then just lift up the handles simultaneously and walk the cover towards the rear of the camper. It's pretty easy as long as the broom handles or poles your using are long enough to get over the A/C unit. Since the cover was reversed on the ground and its lifted rearward, it lays on the roof top with the correct side up. Easy.
