Page 12> |
| Author | ||
rawest50
Joined: 07 Mar 2017 Location: Arkansas Online Status: Offline Posts: 440 |
Topic: Electrical taillight problemPosted: 25 Jun 2017 at 5:42pm |
I noticed last night my right RPod led taillight was on but very dim. The Pod is parked in my driveway and connected electrically to my house power. Nothing hooked to my 7 point trailer connection. When I shut off the power from the house the light went out. What is going on?
2017.5 RPod 179
2017 Jeep Unlimited Wrangler 2017 Chevy Colorado Z71 Off Road Crew Cab 2 Weiner dogs Great wife puts up with my BS ❤️ Thoroughbred Racing.
Posted: 25 Jun 2017 at 9:18pm |
Wire going to light has a nick in the insulation where it crosses another 12V line that has power being supplied by the converter? Polarity problem? I take it this does not happen when the battery/batteries are supplying power but only when the R-Pod is plugged in and presumably, the converter is supplying 12V power?
Edit: What is more worrying is if there is a piece of 120V wiring that is leaking current to the frame. This is going to be something you will want to get checked out. Please make an appointment with your dealer to get this checked. |
rawest50
Posted: 26 Jun 2017 at 8:53am |
Thanks.
2017.5 RPod 179
rawest50
Posted: 26 Jun 2017 at 12:51pm |
Is there anyway I can check this?
2017.5 RPod 179
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2735 |
Posted: 26 Jun 2017 at 12:58pm |
A DVM is your friend. I would check the voltage going to your taillight to see what kind of voltage is getting there (e.g. 12VDC or something else). Troubleshoot from there.
rawest50
Posted: 09 Jul 2017 at 4:25pm |
I called my dealer. Weeks before they can look at it. We have a week long trip next weeks and have already spent a lot of money for sites and events in the area. Anything I can do? How big a problem is it? I am not electrically inclined so I am clueless. |
2017.5 RPod 179
Posted: 09 Jul 2017 at 4:52pm |
One thing to check.. look at the 7 way, make sure it is clean and dry, they get wet, can short a bit.. cause issues. The running light circuit is right next to the 12v hot..
rawest50
Posted: 10 Jul 2017 at 7:27pm |
I checked my 7 point connection on my trailer. Wow. It was wet and copper corrosion was present. Had a cover cap on on it but I noticed the groove was not aligned with the connector. Left a gap for water to enter. With the rain we had it probably funneled water into the connection. He is my question. Pod connected to house power and battery at full charge, what you mentioned could cause my tail light to glow? |
2017.5 RPod 179
Posted: 10 Jul 2017 at 7:49pm |
See if you can clean it out, then squirt in some DC4 or similar dielectric goo. The DC4 is hydro-phobic, and is used in a lot of applications where you don't water to get in. It's also non-conductive.
rawest50
Posted: 12 Jul 2017 at 10:19am |
I ordered the DC 4. I am a little confused. If it is non-conductive will it not interfere with the 7 point connection of the vehicle to R Pod connection? Coat the connectors? It looks like a great product since it is used in the aircraft industry. |
2017.5 RPod 179
Page 12> |
