LED strip on outside of Pod |
Taospod ![]() Newbie ![]() ![]() Joined: 30 Jul 2016 Location: Taos, NM Online Status: Offline Posts: 12 |
![]() ![]() ![]() ![]() Posted: 01 Jun 2017 at 10:43am |
Have a new awning (Bear Creek) for my 179 and want to apply white waterproof LED strip (Amazon GALYGG) above door and along top side of RV for illumination under awning while parked. Have provided switched 12v DC power for end of strip. Has anyone any experience with the double sided sticky tape on the LED strip? I am concerned that it will come off while driving. Any suggestions to further strengthen the bond between the strip and the fiberglass side of the R-Pod would be greatly appreciated.
moseyman ![]() Newbie ![]() Joined: 15 May 2017 Location: Middle Georgia Online Status: Offline Posts: 22 |
An earlier post discussed adhering LED strip-lighting to the exterior of the POD. I believe the poster used silicon caulk to strengthen the bond. I'll try to find it and post the link .
I have a similar need for advice: I want to mount LED strip lights along the underside of the metal case of the Thule awning on my 2017 RPOD 180. Any suggestions for making sure I don't lose them along the highway? |
cjscinta ![]() Groupie ![]() ![]() Joined: 21 Nov 2016 Location: Franklin, TN Online Status: Offline Posts: 84 |
I just did this. I put an led strip on the underside of the awning. I watched a lot of YouTube videos first and it seems first of all, all the led lights you buy on Amazon are from china and are not great quality. I bought the one with the best reviews and wasn't impressed. Be sure to get the kind that are somewhat waterproof. The tape that was on the backside of the strip wasn't even sticking to the strip so I went to the box store and bought some outdoor use 3m high bond double sided tape. Cleaned the underside with denatured alcohol first then applied. 900 miles so far and they are still sticking well. I just used the power supply included and just plug them into my outside receptacle but I really wanted to hard wire them through the outside light but haven't attempted that. I just disconnect them at the light strip and stow the power supply for travel. Seems to work pretty good.
2017 R-pod 179
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1455 |
Watch your voltages. The receptacle is 120v and the light is 12v. TT |
FJ Cruiser |
Thx for the response. My lights are on order and so is a roll of clear Gorilla tape.
But, after your response, I may reconsider that adhesive solution and opt for a double-sided tape. |
voisj ![]() Senior Member ![]() Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Taospod,
Here's what i did for the LED lights, I put the led strip lights under the C channel and ran a wire down to the rear storage compartment where I installed switches. Yes, the ebay stick on waterproof led strips are very poor quality, but I got them to work with a little moxie. They have been on now for 5 months and still working good. I also put a strip on the lower C channel to light up the ground and in the storage compartments. The ones i find work best are the 5050 waterproof soft white, the colored ones remotes (three times) failed after two weeks each. I drilled a small hole just under the rear of the C channel and used a grommet and silicone and ran the wire down the insde of the closet wall, (180 only). On the upper C channel I stuck them on and they fell off by morning so I re-applied them and ran a small bead of silicone all the way down each side of the strip, it took some time but they are holding well. ![]() They are dimmable and look way brighter in the picture than they actually are. ![]() You can see the remote in the storage compartment. ![]() There is a little more info in my all my 180 mods post. rgds John
hadserub ![]() Newbie ![]() ![]() Joined: 05 Nov 2021 Online Status: Offline Posts: 1 |
I wouldn't advise a simple double-sided tape, especially when it comes to waterproof LED strip lights. Since they are exposed to all kinds of weather, it would be good to make sure that the tape on the back of the lights is the best one you can find. I know for a fact that the led strip lights uk have a pretty resistant tape on the back of their waterproof stip lights. It's what they're known for the best. Anyways, you should rule out other factors first. For example, the strip can fall off because of a dirty surface, UV exposure, improper storage or calculations, and so many more motives.
