Page 12> |
Johncmarshjr
Joined: 24 May 2017 Location: Maine Online Status: Offline Posts: 21 |
Calendar Event: Wheel bearingsPosted: 24 May 2017 at 12:05pm |
Does anyone know what size beRing buddy is needed for a 2016 r pod 179?
ALICE
Posted: 24 May 2017 at 1:04pm |
None. Your hubs have a lube system in place. The top of the "hub cap" pops off, under you will find a rubber cover, remove it, you will find a zert.
Elevate wheel so it can be rotated, while rotating pump until fresh new grease comes out the front. Done. |
ronahue
Joined: 02 Jun 2015 Location: Massachusetts Online Status: Offline Posts: 317 |
Posted: 24 May 2017 at 1:24pm |
Everything furpod says but you can put to much grease in and it may end up on your brake pads as I found out. Which while not a big deal it did take a whole can of brake cleaner to get it off.
Ron & Sharon
2015 R-Pod 179 2022 Nissan Frontier No trees were harmed in the sending of this message but a billion electrons were really agitated |
Johncmarshjr
Posted: 24 May 2017 at 2:26pm |
Thank you. Not sure what a zert is, but I will take a look. I was thinking that a bearing buddy like on my boat trailer would be a great addition.
ALICE
Subzilla
Joined: 23 Jan 2017 Location: Concord, NC Online Status: Offline Posts: 302 |
Posted: 24 May 2017 at 3:06pm |
zert = grease fitting
Mark
Johncmarshjr
Posted: 24 May 2017 at 3:14pm |
Thank you. Something new every day.
ALICE
Johncmarshjr
Posted: 24 May 2017 at 3:15pm |
Does anyone know how to access the slideout motor in the 179 pod?
ALICE
Posted: 24 May 2017 at 3:18pm |
It has two. Hopefully you will NEVER need to mess with them. Google "shwintek slide motor"
ronahue
Posted: 24 May 2017 at 3:30pm |
This video will give you an idea how it works for manual retraction:
https://www.youtube.com/watch?v=YzqbvwCJpNU
Ron & Sharon
Posted: 24 May 2017 at 3:57pm |
It is actually a Zerk fitting. The patent for the Zerk fitting was granted to Oscar U. Zerk in January 1929, and the assignee was the Alemite Manufacturing Corporation[1] (thus the eponymous names for the fittings). Alemite was already marketing ball check valves to accept grease supplied under pressure from a grease gun, such as for car and truck chassis lubrication points, both for OEM installations and for aftermarket upgrade kits which would screw in as replacements for stock grease cups. But Zerk's fitting was an improved style, less vulnerable to dirt and more forgiving of angled approach. Today, many companies make these grease fittings. |
Page 12> |
