  New Posts New Posts RSS Feed: Help!! Dead battery
Topic ClosedHelp!! Dead battery
Eevanoff View Drop Down
Direct Link To This Post Topic: Help!! Dead battery
    Posted: 01 Jul 2017 at 8:21am
Just a follow up to help others: The Jenson has a 10 amp fuse in the power line going into the unit
You will need to remove the four screws and slide the unit out from the wall. Detach the power cord and you will see the 10 amp blade fuse. Remove and inspect. Our fuse was blown and after replacing unit works fine. Smile
Direct Link To This Post Posted: 20 May 2017 at 9:03am
Old style (2015) don't rotate or raise. It's an Omni-directional with PA.
SDTrialer View Drop Down
Direct Link To This Post Posted: 20 May 2017 at 8:01am
My antenna does not raise, it swivels around to get signals.
Direct Link To This Post Posted: 20 May 2017 at 8:00am
Direct Link To This Post Posted: 20 May 2017 at 7:42am
Would like to know what fuse is for the Jensen audio system? Unit not working at all. No lights, etc. reset didn't help.
Also, I can't find the control / crank to raise the tv antenna!
Thanks!
Direct Link To This Post Posted: 19 May 2017 at 9:47pm
Glad it was an inexpensive fix for you.
Direct Link To This Post Posted: 19 May 2017 at 9:02pm
Thanks to the forum, turns out the 40 amp fuse was blown. Went to an Auto Zone nearby and bought a package for under four bucks. Problem solved!
Direct Link To This Post Posted: 14 May 2017 at 9:08am
Glad you got it figured out. Happy camping!
p.s. Check your location. It says you are from Georgi Confused I know you mean Georgia.
DawgLady View Drop Down
Direct Link To This Post Posted: 13 May 2017 at 9:19pm
Thanks for all your help. Turns out the battery was the problem and wound up having to purchase a new one. All is working now.
Sara
Dawg Lady
2016 R-180 "Lizzy"
Georgia
Direct Link To This Post Posted: 13 May 2017 at 10:03am
A) how do you know the battery was fully charged?
B) what all was running on 12v?
C) if the converter is getting 120v, and not producing 12v, it may be bad. But it may be a tripped breaker, blown fuse or loose wire.
