  New Posts New Posts RSS Feed: Door seals, slide out, windows
Topic ClosedDoor seals, slide out, windows
rawest50 View Drop Down
Direct Link To This Post Topic: Door seals, slide out, windows
    Posted: 02 May 2017 at 10:06am
New to podding. When doing preventative maintenance what brand of door seal, window and slide out products do you use for you seals. I remember the dealer telling me to make sure I did use a product to keep them flexible.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Direct Link To This Post Posted: 02 May 2017 at 10:13am
I use Protect All Slide Out Rubber Seal Treatment. I use a lubricant spray with Teflon for lubricating the slide-out track and rollers.
TheBum View Drop Down
Direct Link To This Post Posted: 02 May 2017 at 11:12am
It's not the silicone spray with Teflon, is it? I have some of that and it's in a rattle can, which I find somewhat amusing.
Direct Link To This Post Posted: 02 May 2017 at 11:23am
The lubricant spray I have been using is Du Pont Multi-Use Lubricant with Teflon. Some people use CRC lubricant. Protect All makes a dry lubricant which would be useful for the mechanisms as well. If you are asking about the Rubber Seal Treatment, no, it isn't a silicone spray. It is a foam that cleans and conditions the rubber seals. It would not be good for lubricating mechanisms.
Danielw1 View Drop Down
Direct Link To This Post Posted: 02 May 2017 at 10:29pm
Stephen, do you have a brand of the foam cleaner? My trailer is in need of this as well. I noticed some seals sticking when opening. I can contribute one for the lock mechanisms. Lock-ease graphite spray. Did wonders for all the sticky locks, spray it directly inside keyhole and work back and forth with key
Direct Link To This Post Posted: 03 May 2017 at 8:33am
The Protect All Rubber Seal Treatment I mentioned above is what I use on all the rubber seals. Clean off any surface that the seals touch as well as treating the seals. For example, clean the inside of the door to the storage area where the seal touches to remove any residue that might be causing the rubber seal to stick.
Direct Link To This Post Posted: 04 May 2017 at 9:10am
Ok I see it now. Not sure how I missed that. Thanks
