  New Posts New Posts RSS Feed: Which Pod should we buy!!??
Topic ClosedWhich Pod should we buy!!?? - Event Date: 04 Sep 2017 - 06 Sep 2017
SqueakyToy17 View Drop Down
Direct Link To This Post Calendar Event: Which Pod should we buy!!??
    Posted: 12 Apr 2017 at 3:45pm
Hellooo -
I just bought and rPod 179 with the rDome room and it is perfect for me (and 2 grandchildren, 2 LARGE dogs and 1 small one). Love the bit of extra room the slide out provides. The bathroom is emergencies only (night time). Plenty of space for stuff (old camping stuff plus necessary trailer things).
We don't spend a lot of time inside when camping. The only real "TV" thing we do is night time movie (normally on a portable player), so can't really address your question on watching games. Having the Bluetooth system is a boon!
The big thing for me was having A/C for the wicked hot days and the rDome room so the one dog who sleeps in her kennel would be protected, decrease mud/dirt flow into the trailer and we could always sit out there with the dogs if the weather turns yucky and I don't feel like doing the pop ups during short weekends. :)
Good luck deciding!!
flagrv View Drop Down
Direct Link To This Post Posted: 17 Apr 2017 at 10:34pm
Peter and Ritamarie
2018 Rpod 180
Honda Pilot
Direct Link To This Post Posted: 17 Apr 2017 at 10:43pm
Thank you to everyone for the great advice! We visited a dealer last week who had both the 179 and 180, side by side, and with all your input and for what we were looking for, the 180 was our best choice! We are traveling to pick it up next week and already have some great trip ideas.
Next question!!! What are some things we need to be safe, comfortable and happy?? Is there a "Resource 101" for new rv owners? Just the two of us, would like to be as simple but efficient as possible.
Hope to see you on the road!
Peter and Ritamarie
2018 Rpod 180
Honda Pilot
Direct Link To This Post Posted: 18 Apr 2017 at 5:48am
Congrats on your 180!!
Richand Cindy View Drop Down
Direct Link To This Post Posted: 18 Apr 2017 at 6:31pm
Here is our list made taken from help on this board
RV Assessory Checklist (items you need to buy, should buy, or just some that are nice to have)
Extended warranty.  Do not buy third party.  Forest River sells a one year extended warranty for $150.00 The dealer makes no money off of it and may not tell you about it and try to sell you their version (which legally cannot be called a warranty – it is an extended service plan).  You must act quickly, as offer expires ten days after purchase!.  Call Forest River directly if dealer acts ignorant.  Dealer service plans are generally expensive and most reviews are negative.  Some dealers include a free unlimited warranty.  This is not a scam but may not be a good deal.  You have to bring you RV back to dealer once a year for $150 inspection to keep warranty active.  And then it does not really warranty the RV (leaks, axle breaks) but rather the components (refrig, heater).  Only worth buying at a dealer that includes it if they do not charge more for the RV.  One dealer who was $3000 more than another said, “but the warranty is free and that’s worth the $3000 difference!”
Brake controller – Even if TV has towing package it probably lacks a break controller.  Tekumsa P2 is highly rated but more expensive.  The less expensive the unit the more it has to be in a fixed position (i.e. parallel to ground).  It comes with wires to splice into TV however most tow packages already have the female harness so only need to buy male harness for your vehicle (around $18) then no searching for the correct wires to splice into, and you can remove unit at will.  An internet search for your TV will let you know where to find the hitch.  On our Jeep Cherokee it was hidden away and we could not find it until we found a UTube video demonstration.
Weight distribution (WDH) and anti sway
-Equal-i-zer weight distribution hitch 10,000 lbs $408  includes 4 pt friction sway control.
-Blue OX is also highly rated.  It prevents sway instead of correcting it.  It is $600 and easier to connect.  Get 350 lb tongue weight version
Also popular is the Fastway E2 600 tongue weight model.  It is cheapest of the three
-There are numerous cheaper options.  But you may not be able to back up and/or do not have anti sway, only weight distribution.  Most people say anti-sway is required but WDH is not necessary as larger tow vehicles can handle it well.
Other items
             White water hose (for drinking water only) 25’ Camco $9.97
             Garden water hose (for black water flush and all other washing)
             Water filter with right angle
             Water pressure regulator
                Y connector to attach two hoses to single water line
             Oxy-Kem holding tank treatment.  Turn off vent fan when going to the bathroom.  Always wait until black tank is 2/3 full before emptying
             Sewer hose 2 x 10’ is better than single 15 foot (Valterra D04-0275 newer version comes with clear elbow $50.50).  Reported to have less leaks than Camco model
             Sewer elbow to connect to ground hole (comes with Valterra above)
             Sewer elbow clear to connect to RV to see when water is clean Valterra T1026  $11.50 (also comes with Valterra above)
             Sewer hose holder to keep hose slanted to ground Camco 43051 20’ $22.94
             Disposable gloves for cleaning out holding tanks (or strong rubber gloves to re-use and save the environment)
             NCVT Fluke volt alert (looks like a penlight)– standing on the ground touch the door frame or steps if there is voltage leak it will light up preventing a shock.  Do it when first setting up camp and connecting electric. Not needed if you get surge protection (see below)
             Tire leveling plastic with chock for under tires
             Plastic pads for stabilizers (Do not use wood)
             Lock for trailer hitch to prevent someone from stealing your RV when left alone unhooked
             Leveling guides. One type goes on hitch and turns to tell you how many inches to raise RV. Other types stick to side walls.
             Propane tank gauge.  May need to get second tank but try it first with one tank.
             Bug and rodent screens – Spiders in furnace, refrigerator and hot water heater can do damage.  Need to get screens for all vents.  Camco 42154 for Dometic refrigerator Pack of 6 vents $15.88.  Camco 42141 furnace vent screen 2 Pack $10.86. Camco 42145 Large screen for water heater $16.00
             Lawn mat (Do not use plastic grass – stays wet) use porous material made for RVing
             Dust broom with pan
             Lanterns and flashlight
             Spare fuses
             BBQ Grill –  can get propane now that 2017.5 RV has quick connector
             Propane hose extension 10 foot Camco $21.26 (not the standard size 3/8”).  Wiil need a bunch of adapters to fit your grill.
             Sticky mats to keep things on the counter
             Wood dowels to keep windows closed and locked – so they do not open during drives
             Expandable drapery rods to put in refrigerator to hold food in place
             Oxygenics  BodySpa RV shower kit – white (Model ETL26781) Amazon $31.13.  Sends water at higher pressure thus using less water for a shower.  Great product reviews, really works. Made for RV
Replace mattress
-11” NuForm Quilted pillow top memory foam short queen 60 x 74 (RPOD  is 74”) RV size $258 price raised to $279 at Overstock.  Regular queen is 60 x 80
Replace 6 gal water heater with tankless unlimited hot water (Very optional)
-Truma Aqua Go  basic model is $1099.  Could always add it later, if running out of hot water is an issue.  It is said that running water heater on both propane and electric at the same heats up water fast. So probably will be fine with existing 6 gal heater, especially if you can take short showers.  Some dealers however will give you trade in value (up to $300) for turning in a new unused water heater.  So check with you dealer as it may be cheaper to do it at time of delivery before using the standard water heater.  Do not buy any other brand, they are half the price but are all terrible!!!
Add surge protection to RV
-Progressive industries EMS-PT30C Portable RV surge protector 30 AMP.  Comes with metal hook to be able to lock it onto the electric box so that it is not stolen.  $235.00.  This is better than just surge protection since it will also shut off current if it goes too low or is wired wrong.  Even better, get the hard wired version (HW30C same price) so no worries about getting stolen.  May need to have dealer install as it (around $200) involves cutting into electric lines.  Also has a low hum but to eliminate it people report using rubber spacers when attaching it to RV floor.
Direct Link To This Post Posted: 18 Apr 2017 at 6:48pm
Nice job putting all that together!
Direct Link To This Post Posted: 18 Apr 2017 at 8:03pm
WOW!  Thanks for that fantastic list!  As we are graduating from tenting to Rpod...ing, we sure appreciate all the help and advice.
Peter and Ritamarie
2018 Rpod 180
Honda Pilot
Direct Link To This Post Posted: 19 Apr 2017 at 9:21am
You're welcome.  One change I would make.  Despite moving the sewer hose compartment further back on the RPOD and thus bigger it will NOT hold two ten foot pipes.  It misses by about 6 inches.  I could only fit one 10 foot piece in so I hope I never have to use 20'.  I would go with either a 10 footer or a 15 foot hose
rda54 View Drop Down
Direct Link To This Post Posted: 19 Apr 2017 at 11:31am
Why do you say not to use wood?
Ronald & Lonna
2014 178
2016 Chevy 1500
Direct Link To This Post Posted: 19 Apr 2017 at 11:44am
1. weight
2. no moisture retention
3. less likely to pick up and carry pests from one location to another.
