Page <123> |
Topic: Another tow vehicle questionPosted: 18 Apr 2017 at 4:48pm |
+1
Leo B
Posted: 18 Apr 2017 at 4:53pm |
+2
2025 Ford Transit Camper van 2017 Ford F150 Previously owner 2021 Vista Cruiser 19 csk 2015 Rpod 179 2010 Rpod 171 |
CharlieM
Posted: 18 Apr 2017 at 4:58pm |
It seems daunting but we've all been there and somehow figured it out. There is a lot of personal opinion/preference surrounding WDH and sway control but IMO you should definitely use WDH/sway control with the short wheelbase Jeep. When the trailer puts weight on the hitch behind the Jeep's rear axle the front axle tends to get lighter and rise. This adversely affects steering and braking. The WDH will correct this. The WDH will also lock the trailer and Jeep bodies together into one longer body, reducing porpoising and bouncing when going over dips and bumps. With the the short, stiff Jeep that will beat you to death on a long trip. A combination hitch like the E2 or Equalizer provides both WD and SC which need not be disconnected when backing up. The separate friction type sway controllers must be disconnected when you back up. Forget to do that and you bend/destroy the device. I don't see a need to modify the Jeep suspension but you should have a auxiliary transmission cooler and frame mounted class III or IV hitch. You'll also need an electric brake controller such as the Tekonsha P3. |
Posted: 18 Apr 2017 at 5:09pm |
+1 to CharlieM.
SEW83
Joined: 16 Apr 2017 Location: Pensacola Online Status: Offline Posts: 7 |
Posted: 18 Apr 2017 at 5:17pm |
3500 with a hitch rate of 350#
Posted: 18 Apr 2017 at 5:23pm |
IMO, you need a WDH. You are at the max for your vehicle. On my 178 the tongue weight is 377 lbs. Ready to roll. I have done suspension enhancements all my life, everything to springs to bags to lifts, for drag racing and towing. You can't make up for capacity and wheelbase issues. You need an assist.
SEW83
Posted: 18 Apr 2017 at 7:27pm |
Thanks guys.. I will get the WDH and sway. Appreciate the input. I'm 56 yrs old and this is my FIRST major purchase all by myself. I've always had a husband to figure this kind of stuff. But that's ok, I'm learning and growing and can't wait to get my 179.
dr2428
Joined: 13 Aug 2016 Location: Nebraska Online Status: Offline Posts: 70 |
Posted: 19 Apr 2017 at 11:34am |
Hello,
I tow my 179 with a 2016 Santa Fe, same 290HP engine and trans if same year. I'm pretty sure my 5000lb tow rating is based on use of WD, honestly it works so well to distribute the weight that I would not tow without it, I have done so for 1/2 block just to move it and it was obvious I had much less control than with the WD. The WD dramatically reduces the bouncing from bumps and uneven terrain which contributes to greater control. My Santa Fe pulls the 179 almost effortlessly, I do not tow faster than 65mph, usually about 60mph but was able to maintain 65mph up a very steep 1/2 mile hill on I80. There is no overdrive lock out so I shift usually manually. I passed up a 2017 Sorrento which would have been cheaper but I was told by the hitch guy that the hitches were not rated for use with WD. The hitches on Etrailer show "Not rated for use with weight distribution systems" in their specs. I thought I saw a post on this forum that addressed that but cannot find it. I would check with a hitch shop, and Kia on that one. I see a lot of posts on this forum saying that a 1/2 ton pickup/SUV is a minimum but I'm convinced that mid size SUVs like my Santa Fe are a good option that can be equipped to tow safely. In my case, a pickup does not fit our lifestyle at this time. In any case, the first piece of safety equipment needed is a good head on your shoulders. Good luck |
2017 RPod 179
2018 Chevy Colorado Z71 4x4 |
john in idaho
Joined: 04 Nov 2014 Location: Eagle Idaho Online Status: Offline Posts: 613 |
Posted: 19 Apr 2017 at 5:49pm |
A cross wind in Wyoming or Idaho will make you a believer is sway control. If it really is blowing it is far wiser to stop somewhere , especially with a light weight TV. If you drive at 60 or 62 you will never have to pass anyone and try to get back in the lane in a reasonable distance.
Posted: 19 Apr 2017 at 8:33pm |
Double that if you encounter ice like we did. In our case, even sway control was not enough. |
Page <123> |
