Irish Tom
Joined: 27 Jul 2015 Online Status: Offline Posts: 24 |
Calendar Event: 178 Door is hard to openPosted: 10 Apr 2017 at 12:54pm |
My 2015 178 Pod door has always been really tight and does not open freely.
You can see the hinges flex when opening or closing the door. I have tried to lubricate the hinges but it did not help. Any thoughts. Thanks, Irish Tom 2015 178 2014 Ford Explorer Happy Wife
Posted: 10 Apr 2017 at 1:14pm |
I had to hit mine up with Teflon lubricant spray a couple of times after this winter's trip. I think the salt from the roads got in there easier than the lubricant did. After spraying, take a rag and rub it in. That seemed to help when I did it.
Bugout
Joined: 01 Jan 2017 Location: S caroline Online Status: Offline Posts: 117 |
Posted: 10 Apr 2017 at 1:20pm |
The door hinge is is made that way so it won't blow in the wind
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
Posted: 10 Apr 2017 at 3:17pm |
I know that it is made that way. However, after last winter's travel, it was even worse than normal and creaking badly. The lubrication helped, and it still holds when it is open.
TheBum
Posted: 10 Apr 2017 at 5:08pm |
I was having a similar issue this weekend. I found that the screws on one of the hinges on the screen door were loose. Once I tightened them, the doors closed much more easily.
Also, I found that direct sunlight on the door will make it expand, which makes it hard to close. By evening, it was opening and closing much more easily. |
Posted: 10 Apr 2017 at 5:20pm |
Stephen,
How does one know if they have friction hinges? My door swings like a skirt at a square dance, and I have to use a T latch to keep it open, even in the slightest breeze. BTW- I have used Teflon spray to free hinges up a bit. In a pinch I use garage door lubricant. |
TheBum
Posted: 10 Apr 2017 at 6:08pm |
There should be a sticker either on the door or in the immediate vicinity indicating that it has friction hinges. |
Posted: 10 Apr 2017 at 6:32pm |
NADA, my friend. I was under impression 179s had friction hinges.
Irish Tom
Posted: 11 Apr 2017 at 10:16am |
Mike:
We both have 2015 178's You door swings like a skirt in the breeze. My door is stiffer than a cob. My screen door swings freely. I wonder which door condition is correct? Irish Tom |
Posted: 11 Apr 2017 at 2:33pm |
Irish Tom,
I have no idea, I will say I have no friction hinges, do you have a decal that says you do? |
