Page <1 234 |
CharlieM
Topic: 1 or 2 new batteries?Posted: 08 Apr 2017 at 10:20am |
Trojan T-105s are the gold standard. Interstates are OK if they're the GC2-XHDs. Others like Duracell from Sam's, WallyWorld, Batteries Plus Bulbs, etc. may be OK too, but not quite as good. Weight is the thing to look for. Deep cycle capacity is directly related to the amount and weight of lead. The more lead the better.
JandL
Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
Posted: 08 Apr 2017 at 10:06am |
Costco has the Interstate 6 volt golf cart battery's GC2 for $83.99 each + core charge. Another thing to consider is going solar to charge the battery. That's what I have and it works great for my single battery set up
JandL
2013 Honda Ridgeline 2012 177 2 Paynes in a Pod |
Danielw1
Joined: 01 Apr 2017 Location: Oregon Online Status: Offline Posts: 115 |
Posted: 08 Apr 2017 at 9:53am |
[/QUOTE]If you plan on camping off the grid the final solution should be two 6V GC2 golf cart batteries in series. That will give you a capacity of 220AH. Adding a second 12V battery similar to the Gp24 OEM supplied battery will give you 2x70=140 AH or 64% of the GC2 capacity. Adding the second 12V battery now only prolongs the waste of money and lack of performance. Bite the bullet now and go for GC2s.
[/QUOTE] This I think is the answer. I want the capacity there when I need it. I'm pretty suprised at all that runs off the 12v system, this is my first trailer but I thought it was cool. Stereo, fan, pump and only thing its missing is 12v sockets! I can't believe there is none! Thanks for that reply, any recommendations on brand? |
JandL
Posted: 07 Apr 2017 at 10:29am |
Another option if you want to stick to a single battery, you can get a 12 volt GC12V golf cart battery. Their 20 amp hour rate is 155AH, and weigh 90 Lbs. I have on my trailer a single Group 31 that’s rated at 105AH and weighs 59 Lbs. When it dies I will be replacing it with a GC12V battery.
Duracell/East Penn-Deka: SLIGC12V Interstate: 12VGCUTL Crown: CR-GC150 - CR-GC155 Trojan: T1275 - J150 US Battery: US 12VE XC2 - US12V XC2 What is a deep cycle battery |
JandL
CharlieM
Posted: 07 Apr 2017 at 9:51am |
If you plan on camping off the grid the final solution should be two 6V GC2 golf cart batteries in series. That will give you a capacity of 220AH. Adding a second 12V battery similar to the Gp24 OEM supplied battery will give you 2x70=140 AH or 64% of the GC2 capacity. Adding the second 12V battery now only prolongs the waste of money and lack of performance. Bite the bullet now and go for GC2s. |
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3383 |
Posted: 07 Apr 2017 at 5:28am |
Cliff is spot on. In my case we normally dry camp so back in 2011 purchased a similar 12v deep cycle battery. We expect to get 3 days per battery when temps go into the 40's at night and cool days to boot. Always run the refer on propane. If temps are warmer, we get at least an additional days. Beginning year 7 on our batteries. Will seriously consider purchasing 2 6v golf cart batteries for additional amp hours when these use up their useful life.
Podster
Joined: 16 Sep 2014 Location: San Antonio Online Status: Offline Posts: 1108 |
Posted: 06 Apr 2017 at 11:46pm |
Answer is based 100% on your camp style. If you plan to camp most of the time on shore power and maybe a night or two off the grid, conserving power, that one original battery is just fine.
Otherwise you're just throwing money into DC storage capacity that won't be used or used to little to justify the additional cost. |
Cliff & Raelynn
Danielw1
Posted: 06 Apr 2017 at 10:33pm |
I just bought a 2015 178 and the first thing I want to do is add dual batteries. I am debating on adding one to the current factory battery or, getting two brand new high quality batteries. The current battery checked out ok but still thinking I should maybe start fresh. What does everyone think?
Any tips on adding a second battery? |
Page <1 234 |
