  New Posts New Posts RSS Feed: Tow Bar
Topic ClosedTow Bar
actionhooper View Drop Down
Direct Link To This Post Topic: Tow Bar
    Posted: 03 Apr 2017 at 8:17am
I am planning to purchase a new tow bar. Can you guys recommend Blue Ox products? They are currently on sale in 4wheelonline and I am really tempted to place an order. I will be using my Chevrolet Silverado 3500 to tow.
Direct Link To This Post Posted: 03 Apr 2017 at 8:55am
Tow bar? Do you mean weight distribution hitch? A tow bar would be if you want to tow a vehicle behind a motor home. A WD hitch is for towing a trailer.
You might consider the Equal-i-zer 9000600, the Fastway E2 (6000 lb trunion), or the Andersen No-Sway instead. The Blue Ox seems rather expensive in comparison, even at the sale price. I don't have any experience with the Blue Ox. I use the Equal-i-zer hitch myself.
Bama Pod View Drop Down
Direct Link To This Post Posted: 03 Apr 2017 at 2:03pm
You don't need a WDH for a 3500 except maybe for some anti-sway.
Bama Pod
Huntsville, AL
2017 Ford F250
2017 Airstream 26U
Bugout View Drop Down
Direct Link To This Post Posted: 03 Apr 2017 at 2:44pm
May mean anti sway bar
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
Direct Link To This Post Posted: 03 Apr 2017 at 3:01pm
He would have to answer for sure, but when I went to the site he linked, I did not see any sway bars. There were Blue Ox tow bars and Blue Ox WD hitches, but no sway bars.
CharlieM View Drop Down
Direct Link To This Post Posted: 03 Apr 2017 at 4:46pm
With a 3500 you just put the Pod in the back of the truck Wink
Direct Link To This Post Posted: 03 Apr 2017 at 8:07pm
LOL
Direct Link To This Post Posted: 03 Apr 2017 at 8:42pm
Great idea Charlie.  Would probably get better mpg too!  After all, 2 less tires on the road, less resistance!  Won't try that with my 1994 F-150 though, with 309 K miles, would probably break its back.
Direct Link To This Post Posted: 04 Apr 2017 at 6:55am
No kiding
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 04 Apr 2017 at 8:38pm
 Is "tow bar" the same as "ball mount"?  I think you would need one with a significant drop.
The 2 inch square piece of steel that has the tow ball inserted into it is called the ball mount. Depending on the height of the R-Pod coupler, and how much sag you expect to get with your tow vehicle (likely little to none on a big pickup) you will need to get a drop bar to get the ball down to about the same height as the R-Pod coupler. A ball mount that puts the 2 inch ball about an inch higher than the Pod coupler would be good.
 HIGHLY unlikely you would need any WD hitch setup. But a friction sway control would be OK if needed. depends on Pod loading and driving conditions.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
