  New Posts New Posts RSS Feed: Hood River Edition - Clarification Needed
Topic ClosedHood River Edition - Clarification Needed
texman View Drop Down
Direct Link To This Post Topic: Hood River Edition - Clarification Needed
    Posted: 22 Mar 2017 at 4:05pm
This is a pic of the hood river axle that Dromsie has that i am posting for him for clarification.
TexMan 2015 182g
2018 Sequoia
TexManMods
voisj View Drop Down
Direct Link To This Post Posted: 21 Mar 2017 at 10:29pm
You're a wealth of knowledge! Thanks for clearing that up.
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 21 Mar 2017 at 9:18pm
Lippert axles can come in different pitches so the name alone does not indicate which one. The arms on mine are definitely pitched up. If yours had all the weight taken off the axles, you would see the downward pitch as more pronounced. Yours definitely has the newer axle. Our 179 was manufactured 5/15/2015 and we purchased it in December. It is a 2016 model, but between the time ours was made and the time yours was made, the axle change was made along with other changes.
Direct Link To This Post Posted: 21 Mar 2017 at 8:37pm
Stephan,
I just crawled under the 180 and it has the Lippert axle, is this the older axle? The Pod was manufactured on 9/4/15 and I bought it on 6/15/16 the paperwork says it was a 2016 model. and the axel arms are just barely angling down. They also had the early 2017 models on the lot but they were $2000 more and there were only a few minor differences, and were not any higher.
rgds John
SLOPODMODS
John&Sue,SLO,CA
Direct Link To This Post Posted: 21 Mar 2017 at 7:58pm
If it was the 2016s, it was the later ones. I have an early one and it lacks several features of the later 2016 models. It has the older axle, but does have the risers.
Direct Link To This Post Posted: 21 Mar 2017 at 5:53pm
I can tell you my 2016 hre has the relocked axle with the arms pointing down a bit and no risers and parked next to a blue one, 2017 1/2, the blue one is 3" taller and I ~think~ the blue one has 3" risers. And Earlier 2017 green hre's dont.
SLOPODMODS
John&Sue,SLO,CA
Dromsie View Drop Down
Direct Link To This Post Posted: 21 Mar 2017 at 4:36pm
Sorry to be a pain, but all 2017 or just the new blue ones?
Direct Link To This Post Posted: 21 Mar 2017 at 4:20pm
I >think< it was for the 2017 model year.
Direct Link To This Post Posted: 21 Mar 2017 at 10:41am
Mine are pretty much parallel to the ground. Any idea what year they made this change?
Direct Link To This Post Posted: 21 Mar 2017 at 10:34am
To summarize other posts, the pitch angle of the axle was changed so that the height is approximately the same as the old angle with the risers. Some have found it still to be a little low. If you look at the arms on the axle, do they look like they point upward from the axle to the hubs or down? If they point upward, that is the old style. If they point downward, that is the new style.
