  New Posts New Posts RSS Feed: Texman 182g Mods
Topic ClosedTexman 182g Mods
 Post Reply Post Reply Page  <1 7891011 33>
Alloy89 View Drop Down
Direct Link To This Post Topic: Texman 182g Mods
    Posted: 07 Mar 2017 at 3:00pm
Well it's cold today here in San Antonio too, 71 degrees!
texman View Drop Down
Direct Link To This Post Posted: 07 Mar 2017 at 3:09pm
at least your aren't on fire!
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 07 Mar 2017 at 4:47pm
Trade ya, we have 34 degrees
Direct Link To This Post Posted: 09 Mar 2017 at 8:38am
Installed this 300watt inverter last night.  Ran the included leads direct to the battery connections on the power block. Had an open slot for the positive and slid the negative in with the existing.  two small holes and three screws to mount.  I would have preferred to have the inverter mounted behind the wall in the cavity, but i don't want it on all the time and did not want to extend the plug and have another plate.  This model fits perfectly in the storage area right above the power unit. The unit is mainly for an air mattress that draws 105 watts that will be the bed in the front when we squeeze four of us in the pod for a grand canyon trip this summer sometime and the TV if needed.  I may need it for the father in laws CPAP as well.  I don't plan to use it much and so if it gets covered up with "stuff" it wont get hot that way.  when we need it, it is handy and really unseen.  I went with the pure sine wave model to be safe on electronics.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 10 Mar 2017 at 8:49am
My Favorite $16 mod.  Double light over the sink.  Wow-what a diference.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 10 Apr 2017 at 11:22am
making progress on the side table.  Thanks to John and Sue for this idea.  The 182g internal framing is a real challenge when trying to do this mod.  I used a 1" aluminum tubing for my trailer and shelf attachment piece for strength since i only have three attachment point to the trailer over 83".  I used 1/4" nut inserts into the pod at these points.  Also- apparently the studs in the walls are of an s shape.  i cant tell.  But the studfinder and the exterior moisture test revealed studs, but a 1/8" test hole was contraindicated, to say the obvious.  i was glad i drilled very small test holes to verify the stud location before the big 13/32" bore.
The table is made from redwood 2x6 cut into 3/4" pieces and biscuit joined.  a buddy planed it for me and the side you see is the ugly side that needs a little sanding.  The top looks much better.  started staining last night.  The table is exactly 12" wide and 80.5" long.  it fits under the window trim with about a 1/8" to spare.
My plan is to support the table by using some of the 1.5" redwood strips that diagonal from the outer edge to the c channel at the bottom of the pod.  The way the studs worked out, i have to go below, because of the handle on the door.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 17 Apr 2017 at 10:21am
We made a trip with the new table over the weekend.  I was really surprised at how handy that thing is.  We used it for so many different things.  It is a 2x6 redwood ripped to 3/4" and biscuit joined.  The 182g has exactly 13" from the top of the fender to the bottom of the rear window.  The table is 12" wide mounted to 1" square aluminum mounted to the pod with 3x 1/4" nutserts into the studs. The latch is a SS anti rattle boat latch mounted to another 1" aluminum tubing mounted to pod with same size nutsert. I used redwood to support the table the rests on the keder rail very nicely.  The closed travel position is shown and i am still trying to figure out a good way to secure the legs while traveling.  The rubber wire ties work but arent the most stylish. i still need to do some touch up stain and seal on the legs. I used timber stain and spar varnish.
TexMan 2015 182g
2018 Sequoia
TexManMods
voisj View Drop Down
Direct Link To This Post Posted: 19 Apr 2017 at 4:02pm
Texman,I like the way you did the latch,the mounting and the horizontal piece under the front edge,nice mods to the table!
SLOPODMODS
John&Sue,SLO,CA
Pete Brayton View Drop Down
Direct Link To This Post Posted: 19 Apr 2017 at 4:15pm
Do you normally take your pants off to take a picture? LOL
2021 Rpod 196
2013 Ford 150 V8
Direct Link To This Post Posted: 19 Apr 2017 at 4:46pm
LOL
