  New Posts New Posts RSS Feed: Texman 182g Mods
Topic ClosedTexman 182g Mods
 Post Reply Post Reply Page  <1 45678 33>
texman View Drop Down
Direct Link To This Post Topic: Texman 182g Mods
    Posted: 28 Feb 2017 at 8:22am
from amazon  $20.73 and Prime.  This is the one i used.  It has Three electrodes, so is just taped up the third one and that way you don't have to mount a ground wire.
GrillPro 20620 Electric Push Button Igniter
List Price: $31.90
Price: $20.73 Free Shipping for Prime Members
You Save: $11.17 (35%)
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 28 Feb 2017 at 8:23am
Sorry that is so BIG!  Don't need glasses for that one.Tongue
TexMan 2015 182g
2018 Sequoia
TexManMods
jimandclare View Drop Down
Direct Link To This Post Posted: 28 Feb 2017 at 8:37am
Thanks
Jim & Clare
2016 R-pod 178
2014 Ford Edge
Direct Link To This Post Posted: 28 Feb 2017 at 8:40am
Hooked up the 2 gallon pressure tank.  It actually holds about a gallon based on the draw from the antifreeze bottle, but i think the rating is output.  The T that you see is where i spliced it in.  1/2" barbed fitting and then i purchased 4 feet of 1/2" line at Lowes and another 1/2" barb to 1/2" and then a 1/2" to 3/4" brass to connect to the tank and hose clamps.  I moved the water pump about 3" to make a little room for the tank to sit on the floor and have added some packing material underneath the tank for shock absorption.  I still need to strap it with plumbers strapping to secure.  It is a bit tight, but stlll room to set the gallon of antifreeze to winterize.   i relieved the factory pressure from the tank.  When i first hooked it up with the factory loaded air pressure, it only sucked about a 1/2 pint and then the pump shut off.  I just bled air until it seemed to draw the gallon and then quit the bleeding.  i still need to check the air pressure.  Note to those that want to do this:  really easy and cheap, but once you start moving those factory fittings and clamps i had two leaks to fix.  One required a new hose clamp and the other just some tightening.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 28 Feb 2017 at 3:59pm
Nice!
Previously owner
Direct Link To This Post Posted: 28 Feb 2017 at 8:25pm
Texman, followed your directions for the new posting system, worked great!!
Thanks!!
Previously owner
Direct Link To This Post Posted: 28 Feb 2017 at 8:31pm
Cool!
TexMan 2015 182g
2018 Sequoia
TexManMods
riotkayak284 View Drop Down
Direct Link To This Post Posted: 01 Mar 2017 at 11:34am
What is the purpose of this?
Direct Link To This Post Posted: 01 Mar 2017 at 11:35am
Sorry the pressure bottle.
Direct Link To This Post Posted: 01 Mar 2017 at 11:39am
so the water pump does not come on every time you get a drop of water out or the faucet.  The tank allows for some storage of water, but the main purpose is as a "store" of pressure. The tank has a bladder that expands and contracts to keep pressure when you use water in the Pod.  Make sense?
TexMan 2015 182g
2018 Sequoia
TexManMods
