  New Posts New Posts RSS Feed: wheel maintenance
Topic Closedwheel maintenance
Hi-Line View Drop Down
Direct Link To This Post Topic: wheel maintenance
    Posted: 01 Dec 2016 at 7:31pm
My r.pod 179 is a bit over a year old...I've pulled it about 5,500 miles. The Lippert axle brochure that came with the trailer says wheel bearings should be repacked at 12,000 miles or 12 months, whichever comes first. The trailer shop in town (not an RV dealer) recommends repacking every 3 years, although they would agree with the 12,000 mile recommendation. Just wondering what others on this forum think/do? I'm planning a trip to AZ this winter (round trip 3,000 miles) and don't want to push my luck.
Direct Link To This Post Posted: 01 Dec 2016 at 8:41pm
I purchased my 177 in March 2011.  Every spring I use the zerk fitting and fill till full.  In 2014 I did a repack, next spring I will repack again.  Bearings still looked good (in 2014).  Currently have about 25,000 miles on the pod.
sailor323 View Drop Down
Direct Link To This Post Posted: 01 Dec 2016 at 10:25pm
We greased the bearings on our 2016 179 after 12,000 miles using the zerk fitting.  A couple of thousand miles later, one of the bearings failed.  4 or 5 hundred miles later I decided to replace the bearings in the other wheel which turned out to be unnecessary. That being said, I wonder about the admonition to visually inspect and pack the bearings.  That's easy enough to do for the outer bearing.  However, it is impossible to inspect and pack the inner bearing without destroying the seal.  My recommendation is to 1) remove and rebuild the hubs every 12,000 miles [cheap insurance] and 2) carry an extra hub, completely assembled along with a grease gun.  At the same time, I have owned vehicles for over 55 years, driven hundreds of thousands of miles with no maintenance whatsoever to the bearings and the only time that I have ever had a problem with bearings was with a properly maintained bearing.
Direct Link To This Post Posted: 02 Dec 2016 at 10:18am
I used the SuperLube fitting to grease the bearings on our 2016 179 this summer. I made sure to rotate the wheel while pumping in the grease and pumped it until I could see new grease coming out. After cleaning away the excess grease, I replaced the cover and we made another long trip with no incident. We will be taking off on another long trip which will be over 5,000 miles soon. I think I will be okay. I do feel the hubs and wheels when we stop. I have not noticed any unusual heat in either hub, so I think the bearings will be fine for this trip.
TheBum View Drop Down
Direct Link To This Post Posted: 02 Dec 2016 at 11:24am
Are there any YouTube videos showing the method for repacking the bearings for the type of hub in the R-Pods?
Direct Link To This Post Posted: 02 Dec 2016 at 11:50am
Thanks everyone for the good advice!
Direct Link To This Post Posted: 02 Dec 2016 at 12:04pm
Sure is a YouTube video!It is from Lippert, so it should be accurate.
Direct Link To This Post Posted: 02 Dec 2016 at 1:34pm
Video doesn't look to hard
Direct Link To This Post Posted: 02 Dec 2016 at 5:11pm
Thanks for the link!
Direct Link To This Post Posted: 02 Dec 2016 at 5:31pm
The hardest part was figuring out how to lift the 'Pod so that I could rotate the wheel. My jacking block with a small floor jack did the trick.
