  New Posts New Posts RSS Feed: Hitch care
Topic ClosedHitch care
kansasfrogs View Drop Down
Direct Link To This Post Topic: Hitch care
    Posted: 30 Nov 2016 at 2:44pm
Can anyone tell me how to care for the ball and hitch?  Is lubricant necessary and what kind, if so.  The latch on the hitch sometime doesn't want to click in place and our 182 G was newly purchased in May 2016. What am I missing. First time female camper learning the ropes!Embarrassed
FROGGY
TheBum View Drop Down
Direct Link To This Post Posted: 30 Nov 2016 at 3:14pm
You should lubricate the hitch ball and anything else that moves (e.g. WDH bars where they insert into the "head" of the hitch and sway bar balls). One exception is anything that needs friction, such as sway bars (other than the balls) and WDH bars that act as sway bars (other than the front pivots). I use the red sticky grease that's often used for wheel bearings. I get it at Home Depot.
You likely have the tongue too far forward on the ball. When that happens, you can inch the TV forward until the ball is resting against the front edge of the tongue socket. The latch should go down easily then.
No need to be embarrassed. Everybody has to start somewhere.
What part of Kansas do you live in? I grew up in Salina, but I live in Texas now.
Direct Link To This Post Posted: 30 Nov 2016 at 3:32pm
I use Reese Hitch Ball Lube for the hitch ball and for the pivot points on our Equal-i-zer hitch. Equal-i-zer also makes a lubricant for this purpose. If I had not purchased the Reese lubricant, I would have gotten the Equal-i-zer lubricant as it comes in a squeeze tube instead of a jar. For the sway bar brackets, I use the Equal-i-zer Sway Bracket Jacket. This helps quiet the hitch when turning so it does not make all the creaks and groans of an unlubricated bracket. I also added a hitch tightener to lock the shank into the hitch receiver which helps reduce that source of clunking noises.
I agree with TheBum about the hitch and latching. I usually bump the tow vehicle forward once I lower the tongue of the trailer to make sure it is as far forward as it can go. The hitch locks down easily then. I verify that it is fully connected when I raise the tongue once it is locked in order to put on the bars. If it were not connected properly, it would not lift the TV.
I give you a lot of credit for getting out there and trying. There are many men and women who don't even try. It will be easier as you gain experience.
Direct Link To This Post Posted: 30 Nov 2016 at 3:51pm
+1
Previously owner
Direct Link To This Post Posted: 30 Nov 2016 at 3:56pm
I wonder if those Sway Bracket Jackets would fit the Fastway E2 L-brackets.
Shelpod View Drop Down
Direct Link To This Post Posted: 30 Nov 2016 at 5:01pm
Just on caveat.  If you have the Andersen WHD you should not lubricate the ball.  The manual specifically warns against it since the ball is locked in place above and below when the hitch is fully set up and there is a sleeve that the ball post sits in that acts as part of the sway dampening system.
Pod: 2013 178
TV: 2014 Explorer Limited with tow package
Direct Link To This Post Posted: 30 Nov 2016 at 5:41pm
You can also buy a self lubricating ball. We have run one for the last 3 years, very happy with it.
Direct Link To This Post Posted: 30 Nov 2016 at 5:43pm
Thank you all for your help.
FROGGY
Bama Pod View Drop Down
Direct Link To This Post Posted: 30 Nov 2016 at 6:52pm
Hmm - I've never considered that I need to lubricate my balls.
Now on my TODO list.  Thx.
Bama Pod
Huntsville, AL
2017 Ford F250
2017 Airstream 26U
Direct Link To This Post Posted: 30 Nov 2016 at 11:06pm
They might fit. The Equal-i-zer web site (Progress Industries makes both the Equal-i-zer and the Fastway E2) states not to lubricate the brackets on the E2 as the friction of the bars and brackets are the only sway control the E2 has. The Sway Bracket Jacket does reduce friction some also, but the Equal-i-zer also has the hitch head and bar pivot points as part of the sway control also. I did not really notice too much difference with and without them except that it is a lot quieter with them.
I would address the question to the manufacturer. That would be the best and most accurate information on whether they can be used or not.
