Have You Done Any Mods? |
Page <1 3536373839 52> |
| Author | ||
Leo B
Topic: Have You Done Any Mods?Posted: 25 Sep 2016 at 4:34pm |
Have the mods changed the weight of you pod by much?
2025 Ford Transit Camper van 2017 Ford F150 Previously owner 2021 Vista Cruiser 19 csk 2015 Rpod 179 2010 Rpod 171 |
dbrimm
Joined: 10 Apr 2016 Location: Chico/Paradise Online Status: Offline Posts: 19 |
Posted: 25 Sep 2016 at 4:38pm |
Not by a large amount. I don't recall the exact numbers but moving the batteries back and putting the generator up front added about 50lbs (ballpark) to the tongue weight. If memory serves the tongue weight is now in the mid 300's. I haven't noticed any effect on towing (stability or otherwise) and it's really nice to have everything clean and sleek. Not having to fiddle with the genset other than walking out and turning the key is a nice as well of course. |
texman
Joined: 24 Jul 2014 Location: TeXas Online Status: Offline Posts: 446 |
Posted: 31 Oct 2016 at 5:30pm |
RP 182g
stove cover, usb charger, 12v outlet, 12v fan, sealed holes, Zamp solar, jack foot, voltage regulator
rGod2013
Joined: 06 Sep 2016 Location: Chico, CA Online Status: Offline Posts: 19 |
Posted: 01 Nov 2016 at 6:21pm |
2013 rpod 178 1. Remove "head banger box" over bed. 2. Installed shelf over passenger side window, over bed with tv unit from head banger box. 3. Installed nicer shower head. Had to reinforce wall to hold shower. Factory reinforcement in wrong location. 4. Installed lots coat hooks all around. 5. Had to reinforce floor under shower/toilet. Factory keeping costs down. 6. Installed 12" round port hole window in door. 7. From someone else's post I found the over the tank spare toilet paper holder from Wal-mart. Hangs over the sink and ease to remove for shower. 8. Cut open a large access hole in back of shower. Use to reinforce a tv mount being installed on other side. Also, nice access to wires. 9. Found picture frame & small mirror at thrift store. Put them together & mounted on wall above thermostat. 10. Used wide clear packing tape to close small vents on right and left side of A/C. Passenger side was blowing straight down the wall onto the thermostat causing the A/C to continually cycle on and off. Problem solved. Nice when its an easy fix. 11. more to come
birderdiane526
Joined: 08 May 2016 Location: Texas Online Status: Offline Posts: 320 |
Posted: 01 Nov 2016 at 7:16pm |
New for us, a 12v outlet for charging our phones. We added a wire shelf over our bed, from valance to valance. Hung some decorative items for a more homey feel. Love hearing from everyone about their creativity and mods.
Diane and Michael
2016 179 "PIP" (PODDING IN PARADISE) 2007 Toyota Tundra BLOG:Podding in Paradise, birderdiane526.blogspot.com |
Richard7325
Joined: 22 May 2016 Online Status: Offline Posts: 4 |
Posted: 08 Apr 2017 at 2:00pm |
My towing mods...
Rear Anti Sway bar with new OEM Bilstein shocks
e2 WDH Trans cooler the biggest one i could fit Trans gage Brake controller Rear view video to clip on rear view mirror when towing (So I can see the cop coming after me for speeding )
camera on the back |
Posted: 08 Apr 2017 at 2:31pm |
What tow vehicle do you have? How is this anti-sway bar working out?
What camera/display are you using? Source? I like the graphic. |
Bugout
Joined: 01 Jan 2017 Location: S caroline Online Status: Offline Posts: 117 |
Posted: 08 Apr 2017 at 2:41pm |
iBooks like Toyota Tacoma
Jk Aiken South Carolina 2016 178 Toyota Tundra 2017 4.6
Richard7325
Posted: 08 Apr 2017 at 10:26pm |
My tow truck is a 2000 SR5 Toyota Tacoma Pre Runner V6 with close to 200,000 miles. I am the original owner.
The rear Sway bar works great. It keeps the body roll to a minimum and just makes the truck handle better. On the rear view cam I used a wireless receiver and transmitter and took apart a license plate rear view back-up cam and powered it with a 12v cigarette plug. Got it off of Amazon less than $60 for everything. |
gunny
Joined: 04 Oct 2016 Location: portland oregon Online Status: Offline Posts: 6 |
Posted: 25 Apr 2017 at 3:16pm |
I replaced the hot @ cold water drain plugs with water shut off valves. makes it a lot easyer to drain the tank. I got 2 water shut off valves for 1/2 in. pex tubing and 2 small hose clamps at lowes.
