  New Posts New Posts RSS Feed: Towing vehicle
Topic ClosedTowing vehicle - Event Date: 12 Oct 2016 - 25 Dec 2016
Chuckfsc View Drop Down
Direct Link To This Post Calendar Event: Towing vehicle
    Posted: 13 Oct 2016 at 7:11pm
Hello Everyone:
I am thinking to purchase a new Model 179. I have a new Toyota Sienna Minivan. It is rated at 3500 lbs. It has a heavy duty uhaul hitch rated at 4500lbs with 2 in receiver, but it does not have the factory trailer towing package. Lots of people tell me I should not use it to tow the RPod. The RPod has a dry weight of 2640. Has anyone had experience with a minivan pulling their RPod? I would appreciate any guidance on this issue.
Chuckfsc
Direct Link To This Post Posted: 13 Oct 2016 at 7:56pm
We tow our 179 with our Dodge Grand Caravan have for years. We tow in Vermont and New Hampshire and up and down the east coast. We are quite happy with its power and we average 13.5-16.5 mpg when towing depending on the wind.
Direct Link To This Post Posted: 13 Oct 2016 at 10:08pm
Since your Sienna does not have a factory tow package, but an add-on hitch instead, there are a couple of things to note.
First, the hitch may be rated at 4500 lbs, but the vehicle is still rated at 3500 lbs. That is your limit. A heavier-duty hitch does not increase the vehicle's tow capacity. Second, since it is an aftermarket hitch, you should also get a transmission cooler installed. Third, while not strictly necessary, a heavy-duty alternator would not be bad to install either. Fourth, with this vehicle, a weight-transfer hitch with stability is going to be essential. One of these three should be purchased: Equal-i-zer 4-way stabilization hitch; Fastway E-2 hitch; or Andersen No-Sway weight distribution hitch. There are others also, but make sure it combines sway control with weight transfer.
One other thing that we have found that helps. We added an AeroPlus wind deflector from PurpleLine USA. Another one is the AeroShield by Icon. These improve the airflow between the tow vehicle and trailer. Our experience is that it increases our mileage significantly. This is optional though.
I don't think the Sienna's engine is turbocharged. You will find it works okay on flat land and hills. However, it would probably struggle at higher elevations and mountains. This is not to say it won't work. Just understand that you won't be going up 10% inclines at normal highway speed.
Direct Link To This Post Posted: 14 Oct 2016 at 2:30pm
Hello Stephen
Thanks for the good advice. I knew about the weight distribution hitch. Do you think I also need an oil cooler and electronic brakes? Also would you recommend a larger radiator and fan installed?
Thanks
Chuck
Chuckfsc
Direct Link To This Post Posted: 14 Oct 2016 at 3:11pm
The R-Pod comes with electrical brakes. Unless your tow vehicle comes with a built-in trailer brake controller like some of the trucks, you will definitely need to purchase and install a controller. Some people use the Tekonsha Prodigy P3 controller. I chose the Hopkins InSIGHT Flex-Mount trailer brake controller as it gave me better options on where to mount the components. I have been very pleased with the installation.
As for larger radiator and fan, I can't answer than one. What I did is to get an OBDII Scan Tool. I also got a cord to allow flexibility in plugging in and placement of it, but that is optional. I use the Torque Android app on my phone to monitor engine and transmission temperature and other performance parameters. I would recommend getting an OBDII device and then determining whether spending the money on a new radiator and fan are warranted.
CharlieM View Drop Down
Direct Link To This Post Posted: 14 Oct 2016 at 3:12pm
My two cents worth: You should get a transmission fluid cooler and a way to measure transmission temperature such as a ScanGauge or similar device. You absolutely must have an electric brake controller. Without it you are unsafe and illegal in almost every state.
TheBum View Drop Down
Direct Link To This Post Posted: 14 Oct 2016 at 4:14pm
I installed a Husky Quest brake controller. Whichever controller you choose, I'd highly advise one with proportional braking: it measures your rate of deceleration and applies an appropriate amount of braking pressure.
Direct Link To This Post Posted: 14 Oct 2016 at 4:35pm
+1
dr2428 View Drop Down
Direct Link To This Post Posted: 14 Oct 2016 at 6:11pm
StephenH,
     Thanks for the link to the scanner, I've been wanting one but too many to choose from. Good to see one that worked out for someone here, just ordered it. I have a light duty TV, 2016 Santa Fe and have been wanting to be able do monitor temps. I have a spare Android phone which will do fine as a permanent display. Love your mods by the way.
Thanks
2017 RPod 179
2018 Chevy Colorado Z71 4x4
Direct Link To This Post Posted: 14 Oct 2016 at 8:19pm
I'm glad I can help. In addition to a phone, an Android tablet also works and will give you a larger screen. The key thing is that it have Bluetooth connectivity.
