List Your Mods:
 Post Reply Post Reply Page  <1 2324252627 78>
grand beaver View Drop Down
Post Options Post Options   Quote grand beaver Quote  Post ReplyReply Direct Link To This Post Topic: List Your Mods:
    Posted: 21 Sep 2016 at 11:15pm
Thanks StephenH........I respect your opinion as I have read many of your mods and know you know the pods well. I will consider putting some kind of fan behind it. I didn't even consider the air intake for the heater! Our upcoming trip to Boise and The Sawtooths will all be in KOA's with full hookups so I can run a "cooling" fan to push the air around the heater....Thanks again for the input!
birderdiane526 View Drop Down
Post Options Post Options   Quote birderdiane526 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 10:37pm
Your window addition looks terrific!
Diane and Michael
2007 Toyota Tundra
BLOG:Podding in Paradise,
birderdiane526.blogspot.com
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 10:24pm
Originally posted by grand beaver
....I built an air deflector for the heater.
From the front.
Okay. Be cautious about this. If you take the front off of the heater, you will see that the area on the lower-right is an air return. In fact, the whole area around the front of the heater is air return. By putting your box over it, you are restricting airflow so that the hot air output of the heater is pulled right back in. I think you will have problems unless you find a way to allow for cold air return.
What I did was to get a RoadPro RP8000 fan. I put a 12V outlet near the AC outlet, and plug the fan in there. I can also use 8 D-Cell batteries if I want to instead. This sets at the base of the bed blowing outward. It pulls the heat from under the bed and sends it out to the rest of the R-Pod. Since it is not blocking anything, it allows for cold air to return. It is small enough to sit there and not be a trip-hazard.
Post Options Post Options   Quote grand beaver Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 9:57pm
Insulfoam by Carlisle is the lining for the inside of the wood.....I have not used the heater yet. Am I setting my myself up for a hot mess? I don't plan to use the heater for extended periods of time and plan to keep a close eye on the surface temps but I surely don't want to burn down the "Grimpod"?..........All opinions are welcome?.....
scott59 View Drop Down
Post Options Post Options   Quote scott59 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:32pm
Good window mod.........
On the redirection mod for heater, what is the material coating the inside facing wood?
Post Options Post Options   Quote Leo B Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:21pm
That is a really great window mod!!
NutPod View Drop Down
Post Options Post Options   Quote NutPod Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 7:21pm
Hey Groupie I like what you built to redirect the air flow from the heater but can you tell me how hot it gets being that close to the furnace. I built something out of ducting metal and it gets very hot and I'm not sure I like that.
I find that Forest River should have vented the heat out the front of the bed instead of underneath the bed. We just got the R-Pod 180 and when camping in the Rockies for a week and had to use the furnace every night and found the furnace airflow needed to be redirected to get heat to the other side of the Pod.
Post Options Post Options   Quote grand beaver Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 6:35pm
....Installed looking down from the top.
From the front.
....Added a wire shelf over the bed.......
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 9:05pm
The cover I'm referring to is a hard cover over the window.  You'll have to custom match one to your window.  I think you were smart to order a solid window to prevent leaking going down the road.  There is a lot of air pressure on that surface.
I could see mounting a window above the red arrow for more of a skylight feel.
Shelpod View Drop Down
Post Options Post Options   Quote Shelpod Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 1:18pm
Could you reuse the cut out for a cover for the window?  That would maintain the r-pod decal.  You would have to build a frame for that also but it is an idea.
Pod: 2013 178
TV: 2014 Explorer Limited with tow package
