List Your Mods: |
Page <1 2526272829 79> |
Jonknite
Joined: 25 May 2015 Location: Placitas, NM Online Status: Offline Posts: 19 |
Topic: List Your Mods:Posted: 20 Sep 2016 at 12:49pm |
For those that asked, here are the details of my dinette window add-on.
I got the window from Hehr International in Indiana. It is from their 5900 series. They have any size you want and you can get them with or without sliders, tinted etc. I chose a fixed window. If you look at the picture of the R-Pod framework below you can see the bottom rib that I used (Black Arrow). I cut through the middle rib (Blue Arrow) and added a rib below the Red Arrow. You could have a window as high as the red arrow. ![]() Once the window arrived (took 3-4 weeks) I traced the outline onto cardboard to make a template for the frame. I set the pencil so that the outline was about 1/8" bigger all around. To compensate for the curvature of the Pod I made the frame 2 1/4" high. This way the window will be sealed against a flat surface inside and out. I then made a gluing jig for the frame 3/4" smaller than the template as I was using 3/4" pine for the frame. ![]() I traced the four rounded corners onto 2X4's and cut them with a bandsaw. I then cut the 1X3" Pine (trimmed to 2 1/4" wide) pieces to fit between the round corners. I used a good quality exterior wood glue and clamped the whole thing against the jig. I then sanded the whole thing smooth with the following result. ![]() The plywood shims were added because the glass side of the window has a smaller ID than the inside frame and I didn't want it to shift while I installed the window. I then painted it with black Rust-Oleum to match the window frame. I cut a hole on the inside of the POD at about the center point of the window location so that i could accurately find the lower rib. I then cut along the bottom rib as my starting point. Next hold the finished frame against the wall with the bottom lined up with the lower rib and trace around the frame. A jig saw with a short blade was then used to cut out the rest of the wall. I used a short blade so it wouldn't penetrate the outer wall. ![]() Next I used a pencil to transfer the inner cut to the outside wall and cut that out with a longer blade. ![]() Now I glued in a 36" long rib between the inner and outer wall at the top of the hole to give stability to the walls and to have a strong anchor point for the top of the frame. I used high strength construction adhesive. ![]() Next I inserted the frame and screwed it to the bottom and top ribs as well as the ends of the middle (blue arrow) rib that was cut with the hole. ![]() I then applied a liberal amount of silicone caulk to the outside and ran a nice bead on the inside to seal the whole thing up. It was then a simple matter to install the window according to the manufacturers directions. ![]() ![]() |
fwunder
Posted: 20 Sep 2016 at 12:26pm |
Wow Jonknite. Great work on that window! Brave!
This is the cover I bought (December 2013) for my 178. Still in good shape: fred
Jonknite
Posted: 20 Sep 2016 at 11:30am |
Doug,
Can you recommend a good cover?
kkomorn
Joined: 17 Oct 2015 Online Status: Offline Posts: 7 |
Posted: 20 Sep 2016 at 11:28am |
Jonknite - where did you get the window?
Did you consider a slider? Doing that in the spring. Such a sweet adder. It's like a dungeon in the Pod during the day. Thanks! KK
Cap-n-Cray
Joined: 22 Feb 2014 Location: Bainbridge Is Online Status: Offline Posts: 121 |
Posted: 20 Sep 2016 at 12:27am |
Jonknite can you post more photos of your install. Great job and idea. I though of making a type of shim, but your way is better...
Cary
2014 RP-177 |
Bcmckean
Joined: 16 May 2016 Online Status: Offline Posts: 13 |
Posted: 19 Sep 2016 at 9:31pm |
Great, thanks! Looks like they did a good job... and your handy work looks good as well!
CLT-NC R-Podder
Joined: 18 Mar 2016 Online Status: Offline Posts: 8 |
Posted: 19 Sep 2016 at 9:08pm |
We took a drawer from the kitchen cabinet, as well as a piece of the wood we were staining, to Sherwin Williams and they matched it. They did a great job!!
Joe & Erin
2016 178 towed by 2016 Toyota Tacoma double cab 4x4 |
Bcmckean
Posted: 19 Sep 2016 at 8:52pm |
CLT-NC R-Podder Looks great, what color stain did you use to match the rest of the wood?
Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9066 |
And FR said it couldn't be done. I would have loved a window in the front wall in our 171. Make sure you add a cover on the outside when you tow to protect against road debris.
kkomorn
Posted: 19 Sep 2016 at 4:53pm |
That is just awesome. Seriously.
