Page 12> |
Leo B
Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4518 |
Topic: Receiver LoosePosted: 04 Sep 2016 at 9:14pm |
Good news!!
Posted: 04 Sep 2016 at 8:29pm |
Great! I'm glad you found a solution for your problem.
Larabee
Joined: 23 Aug 2016 Online Status: Offline Posts: 13 |
Posted: 04 Sep 2016 at 3:56pm |
Hello Everyone,
Thanks for the feed back. It appears that the hitch has a lot of play when it is in the receiver and since the mountain roads in our coastal Northern California area are pretty bad the noise was generated every time the weight shifted the hitch it made the noise. I purchased a hitch that fits snugger, and the noise and shifting of weight went away. |
Posted: 04 Sep 2016 at 3:41pm |
I thought I would make a couple of more comments about this. Did you notice this noise going down the road straight? Was it when you hit a bump? Was it going around gentle curves or sharp curves? Was it when you were turning a corner left or right? If it was straight and/or bumps, then I would suggest play in the hitch shank and the receiver. This will be banging or clunking noises, but they are not that loud. This type of noise can be minimized with a hitch tightener. If it is on curves, and especially when making a sharp turn, then it is most likely the bars sliding along the brackets. That is metal on metal. It will really make a loud banging or clunking noise as well as groaning noises as the bar slides. The groaning is when it is sliding. The banging is when it has enough friction to hold it long enough to let pressure build and then releases and slides. This type of noise can be reduced by using Sway Bracket Jackets or by greasing the sway brackets. This will reduce sway control a little, but not so much that it negates sway control. Please let us know when you figure out the cause of your noises. |
ToolmanJohn
Joined: 23 Apr 2014 Location: Connecticut Online Status: Offline Posts: 451 |
Posted: 03 Sep 2016 at 8:44pm |
The Anderson hitch , it doesn't matter if the tow ball is greased or not, the tow ball rotates with the trailer anyway. The anti-sway is a friction cup that the ball mounts in, and the WD is accomplished with urethane bumpers mounted to chains instead of spring bars like traditional WD hitches.
I do use grease on the Anderson tow ball, it can make noise. A little lithium quiets it up nicely. I found that it does settle the R-Pod down on uneven roads extremely quickly, and I don't know I'm towing it on the highway, very stable.
Posted: 03 Sep 2016 at 7:47pm |
+1
I used a different style of hitch tightener. Before getting it, we experienced the same clunking noises. You didn't say what hitch you got. We have the Equal-i-zer 4-way stabilization hitch. The bars for that also make groaning and clunking noises. Sway Bracket Jackets from Equal-i-zer quiet those noises. Also, grease the bar pivots per the instructions unless you have the Andersen hitch which shouldn't be greased. |
ToolmanJohn
Posted: 03 Sep 2016 at 6:54pm |
This could be the tow bar has play in the vehicle hitch receiver. Until I installed a clunk stopper on my receiver, it would knock on bumps and turns.
Shown is the anti-rattle shackle ($20), and my old tow bar (I currently use an Anderson tow bar, but I still do use the anti-rattle shackle.). |
Posted: 03 Sep 2016 at 4:44pm |
I think NO. There are subtle noises from receiver in hitch, but hitch pin and receiver holes should match. Ball should be tight, TV receiver fully locked on ball. There is not a lot of room for movement. Don't call - have someone look at it. There is a number of things could be wrong. Really a safety issue.
codycountry
Joined: 26 Jan 2014 Location: Wyo Online Status: Offline Posts: 168 |
Posted: 03 Sep 2016 at 4:03pm |
Two questions: What tow vehicle are you pulling with? When parked flat and level (and hitched up), is the tongue of the rpod level to the ground, or is it pointing up or down from level?
Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1455 |
Posted: 03 Sep 2016 at 3:28pm |
Not really enough info - pics would be great -- but it doesn't sound right to me either. Find someone other than the dealer to inspect it. If there are any loose nuts or bolts, don't tow without tightening them. It could be that you're just new to towing and nothing's wrong, but this is the kind of thing you need to pay attention to. If it doesn't feel right, get it checked out. Way too much at stake to do otherwise.
TT |
FJ Cruiser |
Page 12> |
