  New Posts New Posts RSS Feed: Well, I did it.
Topic ClosedWell, I did it.
 Post Reply Post Reply Page  <1 3456>
Direct Link To This Post Topic: Well, I did it.
    Posted: 07 Sep 2016 at 11:41pm
I don't know Doug, I had a thermostat in the pod that I can read in the house. I didn't stay in the pod but I checked a number of times, never heard the HWH. I'm super happy with the results.
Direct Link To This Post Posted: 07 Sep 2016 at 6:48pm
Sounds like your 2nd test is a nice option to keep the chill away on boondocking trips while conserving energy.  How often did the WH fire up during the two tests?
Direct Link To This Post Posted: 05 Sep 2016 at 2:25pm
Well Doug, it isn't winter yet but it is getting pretty chilly, so it's time for a test for my new heater. The last 2 days day temps were 14 C - 57.2 F night temps were 7 C - 44.6 F. first night I set thermostat 22 C - 71.6 F it kept the temp with no problem, second night I turned off the inline pump and only ran the 2 fans. So the water was moving by convection, the heater held the temp to 16 C - 60.8 F. Nice temp for sleeping.
Direct Link To This Post Posted: 03 Sep 2016 at 9:35pm
SWEET!  There was a discussion on this a while ago and I forgot about it.  I can't wait to hear the results of sea trials this winter.
Direct Link To This Post Posted: 01 Sep 2016 at 7:41pm
I use a 12 volt inline hot water pump TE091.
The thermostat is a cheap Honeywell for a furnace.
Dewinterizing: I just blow out the lines.
CharlieM View Drop Down
Direct Link To This Post Posted: 01 Sep 2016 at 4:57pm
Marwayne,
Since you're into such things you might be interested in my use of the water heater for freeze protection:
http://livinlite-owners.com/thread/1477/fresh-water-anti-freezeup-system
Different camper, but might give you some ideas. I also use it to save on FW and Gray water storage when dry camping.
Podster View Drop Down
Direct Link To This Post Posted: 01 Sep 2016 at 2:20pm
Sonny, how are you going to winterize that thing?
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 01 Sep 2016 at 9:08am
Let me see if I am interpreting the picture correctly.
1. Hot water from the water heater is piped to your new heat exchanger to heat the air.
2. Cool water returning from the heat exchanger goes to the pump and is returned to the cold water line to go back to the water heater.
3. Thermostat controls operation of the pump and fan. Fan can be switched independently to operate if heat is not needed.
With the 179, I added a divider, making a small compartment into which I could install such a heat exchanger and not have it in the exterior storage. That is limited enough as is since it does not go all the way across in the 179. My air return would also have to be different. The remaining questions I have are parts questions. What pump did you use for this? I am going to have to assume it is a 12V pump. What thermostat? For the heat exchanger core, what did you use?
Direct Link To This Post Posted: 01 Sep 2016 at 12:20am
 The heater is thermostat controlled, I can bypass the heater core by closing 2 valves in and out of the HWT. I can also switch off the pump or the fans. The nice part about that is that I can run the fans just for air circulation. The air gets picked up through the vent under the shower, therefor I made the hole
bigger. The big silver blob you see in front of the HWT is the inline water pump. The heater itself is in the outside storage.
Direct Link To This Post Posted: 31 Aug 2016 at 10:35am
Are the fans thermostatically controlled? 1A draw sounds great for off grid heat. And of course, as always, great work and execution.
