Page <12 |
Topic: Battery on Rpod deadPosted: 30 Aug 2016 at 12:02pm |
If it charges them now, it will charge them then. |
john in idaho
Joined: 04 Nov 2014 Location: Eagle Idaho Online Status: Offline Posts: 613 |
Posted: 30 Aug 2016 at 10:49am |
Check the water in the cells.
M&M
Joined: 19 May 2016 Location: Middletown, NJ Online Status: Offline Posts: 80 |
Posted: 30 Aug 2016 at 10:19am |
Jumping in here. If I have a battery cut off switch installed, and have it switched on, will the TV recharge the R-Pod battery while we're driving? Thanks, Marty
2017 179 "Big Sexy"
2012 Honda Pilot |
Posted: 29 Aug 2016 at 9:40pm |
A battery cut-off switch will simplify things for you. Otherwise, you should disconnect the NEGATIVE (-) lead from the battery. Disconnecting the POSITIVE (+) cable can cause some unexpected fireworks if it should contact metal A cut-off switch will keep you from having to mess with the battery terminals. It is not too hard to install. There are several pictures of different ones in the forum including the one shown in my mods. It has come in handy when I was doing some work where I wanted the power cut off. It has also been handy for when I had to take my R-Pod to the dealer for some warranty work.
Jewel59
Joined: 19 May 2016 Online Status: Offline Posts: 70 |
Posted: 29 Aug 2016 at 9:26pm |
Thanks for easing my mind, it can't be charged where I store it so I guess I will learn how to disconnect the battery. Hopefully it will charge up. I don't anticipate much use of the battery so hopefully I didn't cause it to enter into an early death. Live and learn on this one (I'm still new with the the camper thing). I was shocked when i went into the Rpod today and no lights.
CharlieM
Posted: 29 Aug 2016 at 9:02pm |
The RPOD and most other modern campers have a propane detector that draws current from the battery continuously. The RPOD has a small additional load from the thermostat. These loads will deplete a battery in a few weeks. That's why you should disconnect the battery or keep a trickle charger on it when you store the Pod. Having discharged the battery once it will have a shorter life, but should recharge when you plug it in at home. Charge it over night to make sure. Depending on how you use it you may never notice the degradation. Most experts recommend not discharging a battery more than 50% and to never leave it totally discharged for any length of time. The plugin deodorizer will have no effect because it runs on 120V, not 12V.
Posted: 29 Aug 2016 at 8:54pm |
If you have to store the pod where it can't be plugged in, either remove the battery, or install a battery cutoff switch as soon as possible. There are a few phantom loads in the pod that will run the battery down in a couple weeks.
And.. No the plug in didn't do anything, the outlets are on the 120v side. |
Jewel59
Posted: 29 Aug 2016 at 8:41pm |
I've had a great summer getting much use out of my Rpod. The Rpod has sat for the last 3 weeks. I'm taking it out Labor Day weekend. Today I went to the covered storage where I rent a space to store the rood. I found the lights wouldn't come on inside the Rpod. Nothing would operate (slide out) suggesting the battery is dead. I am planning a trip this weekend (with full hookups), will everything else remain uneffected in the Rpod even if the battery won't recharge? I really don't have time to get a new battery. I'm going to bring the Rpod home tomorrow and plug it in. Hopefully the battery will revitalize. I only now learned you should disconnect the battery when the Rpod sits. I didn't the battery would go that quick. With that said, I left a plug in air freshener in the kitchen outlet. Could that have discharged the battery?
Page <12 |
