CharlieM
Topic: Water Pressure Regulators and Flow RatesPosted: 29 Aug 2016 at 6:53pm |
Water pressure regulators are a necessary accessory in
campgrounds to protect against high and damaging pressures. While most
CGs don't exceed 65psi, which is OK for modern campers, some can exceed
100psi which can blow a hose or fitting. That can be a real mess even in
an aluminum camper.
The common Camco Valterra brass inline regulators, even the "high flow" models, do a good job of limiting pressure, but they also limit the flow rate. This is noticeable in the shower and when filling pots. If you get an initial high flow and then it noticeably drop off it's the regulator restricting flow. The standard option is an expensive household regulator such as a Watts, but there is now an alternative. It's a Fairview model WR-RV55: www.fairviewfittings.com/products/fittings/brass-fittings/water-hose-fittings/leadfree-rv-water-pressure-regulator-117627.html They are available from: www.rvwaterfilterstore.com/PressureRegulators.htm I measured the time to fill a 6 gallon jug from my garden pump at 40psi through 20' of 3/4" hose: Open hose, no restriction: 29 sec, 12.4GPM Fairview regulator: 36 sec, 10GPM Camco Valterra "high flow": 50 sec, 7.2GPM This should make a noticeable improvement in show flow, especially at low pressure CGs. |
osage
Joined: 13 Mar 2016 Online Status: Offline Posts: 146 |
Posted: 29 Aug 2016 at 7:27pm |
what did the Camco Valterra reg. do per min.
CharlieM
Posted: 29 Aug 2016 at 8:36pm |
I only measured the Camco Valterra high flow unit. It measured 7.2GPM. They have a "normal" unit, which I also have, but I didn't measure it. It is less than 7.2GPM.
