| Post Reply   | Page <123 |
| TheBum   Senior Member   Joined: 26 Feb 2016 Location: Texas Online Status: Offline Posts: 1407 |  Topic: Inverter/Generator help needed Posted: 11 Jul 2016 at 12:40pm |
   Hondas are known for exceeding their surge ratings, which is one of the things that makes them preferred if money is no object. We just bought one regular EU2000i and one Companion.
 I'm not sure I'd trust a single EU2000i if I'm running anything other than the A/C. Was your battery fully charged? If so, that's probably why it worked: very little power zapped by the converter. | |
| Jackdaddy   Newbie   Joined: 10 Oct 2013 Location: San Gabriel, CA Online Status: Offline Posts: 9 |  Posted: 11 Jul 2016 at 11:52am |
   Hi All, I purchased a Honda EU Invertor 2000i Companion 30a generator a few months ago and finally used it with my 2014 Rpod 182G and it worked great. I was told that it would not power the A/C but those who said it wouldn't were wrong. It was 95 degrees here in San Gabriel, Ca yesterday so I hook up the generator again to just verify it runs the A/C and sure enough it works great. Steve | |
| WillThrill   Senior Member     Joined: 04 Jul 2014 Online Status: Offline Posts: 298 |  Posted: 10 Jul 2016 at 9:56pm |
 +1 A cheap outlet tester that can be bought at a local hardware store will tell the tale.  Just plug it into an AC outlet when you have shore power and see what it reads. And you can turn off the microwave and almost anything else by switching off the appropriate breaker in the panel.  Oftentimes, folks that successfully run their AC with a 2 kW generator have to do this in order to turn off the converter/charger, which can draw several hundred watts if it's charging the batteries. | |
 2014 Hood River 177 2005 GMC Envoy XL | |
| mjh203   Newbie   Joined: 10 Jul 2016 Location: Colorado Online Status: Offline Posts: 19 |  Posted: 10 Jul 2016 at 9:01pm |
   I'll check out the ground issue....thanks!
| furpod   Moderator Group - pHp     Joined: 25 Jul 2011 Location: Central KY Online Status: Offline Posts: 6128 |  Posted: 10 Jul 2016 at 8:57pm |
   That genny should be fine to run the pod as long as it's not the a/c. My bet is a ground issue.  Link. | |
| mjh203   Newbie   Joined: 10 Jul 2016 Location: Colorado Online Status: Offline Posts: 19 |  Posted: 10 Jul 2016 at 7:07pm |
   Hello, I did a bunch of research on portable generators and decided on a new Generac iQ2000 Inverter. It is quieter than a Honda EU2000 and had really good reviews. So, I went on a trip and tried to use this for the first time on my 2015 R-Pod 178. The generator fired right up and gave me the green ready light. As soon as I plug in the camper, it switches to red and will not power anything in the R-Pod. The only things turned on in the camper are the clock on the microwave which instantly comes on with electric and the clock on the Radio/DVD player. I cant turn these off. Everything else was off and/or unplugged. I tested my dads old 1978 camper with the iQ2000 and it worked just fine. Not enough to power the AC, but lights and outlets worked fine. What am I doing wrong? Shouldn't this unit be adequate for this small little camper? Thoughts or suggestions? I went ahead and returned the iQ2000 today. Suggestions from any other R-Pod owners for a good size inverter/generator unit? Thanks | |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
