Tim
Topic: Air Condition Posted: 07 Jul 2016 at 12:06pm |
How do you all recommend setting the fan when running the air? Auto or low? We have a '14 178.
WillThrill
Posted: 07 Jul 2016 at 12:28pm |
In our '14 177, if you set the thermostat to 'cool', the fan runs the entire time, regardless as to whether the air conditioner compressor is running.
If you just want the fan to run, set it to 'fan' and select either 'low' or 'high'. Yours may be different, but I doubt it.
2014 Hood River 177
2005 GMC Envoy XL
Posted: 07 Jul 2016 at 1:09pm |
If you just want the fan to run, set it to 'fan' and select either 'low' or 'high'. Yours may be different, but I doubt it. |
If you set your fan mode from "low" or "HI" to "AU" it will stop that.
Tim
Posted: 07 Jul 2016 at 3:52pm |
That is what I have eperienced...with the air on the fan runs all the time regardless if the compressor is running or not????
TheBum
Posted: 07 Jul 2016 at 5:33pm |
On AU (auto), the fan on our 2016 179's A/C starts up a few seconds before the compressor kicks on and stops a few seconds after the compressor stops. If we have to run A/C at night, we'll usually put the fan on LO to keep the noise down.
Tim
Posted: 09 Aug 2016 at 9:00pm |
How do you remove the air filter from the a/c unit to clean/replace it? Thanks!
Posted: 10 Aug 2016 at 8:34am |
Originally posted by Tim
How do you remove the air filter from the a/c unit to clean/replace it?Thanks! |
There are two of them, on the front of the ceiling unit, they slide out the front. They are side specific.. so pay attention to which is which..
Tim
Posted: 10 Aug 2016 at 9:13am |
Thanks so much! I'll look for them tonite....
Tim
Posted: 10 Aug 2016 at 6:30pm |
Thanks! The reason I could not find the filters is because they were not inserted where you said they were! We found the filters in a stack of manuals. Thanks again, sorry to be a dunce
Posted: 10 Aug 2016 at 8:51pm |
Thanks! The reason I could not find the filters is because they were not inserted where you said they were! We found the filters in a stack of manuals. Thanks again, sorry to be a dunce |
That has been reported by owners more often then it should be. Glad you found them and got them in..
