| Post Reply   |
| john in idaho   Senior Member     Joined: 04 Nov 2014 Location: Eagle Idaho Online Status: Offline Posts: 613 |  Topic: Kick board under refrigerator Posted: 18 Jun 2016 at 4:46pm |
   Model 179.  A roll of paper towels got behind the flimsy kick board, and pulled it loose while putting the slide out.  Has any one figured out a better way to attach it than the 3 screws in chip board just waiting to get pulled out??
| StephenH   podders Helping podders - pHp     Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6463 |  Posted: 18 Jun 2016 at 9:44pm |
   See my mods. I used three toggler anchors. These are the white plastic things that look like wings. I put these into three holes in the aluminum channel and expanded them. I used  plastic washers and caps. The end result is that it looks better and is less likely to be knocked out. I have read also of people using hinges. If by some chance it does get knocked out again, I will go with hinges so it can swing if something gets caught. If you search the forum, you will likely find a post with information about using hinges. | |
 Happy is the man that findeth wisdom,... ouR escaPOD mods Former RPod 179 Current Cherokee Grey Wolf 24 JS | |
| TheBum   Senior Member   Joined: 26 Feb 2016 Location: Texas Online Status: Offline Posts: 1407 |  Posted: 20 Jun 2016 at 1:01pm |
   I added hinges, but they won't help that situation, only when something hits the panel with the slide in. I've been thinking about the possibility of stacking hinges so that the panel can swing both directions but haven't sat down to work out the geometry.
| StephenH   podders Helping podders - pHp     Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6463 |  Posted: 20 Jun 2016 at 3:03pm |
 I had thought about that too, but couldn't quite figure it out either. That's why I went with the anchors in the frame. | |
| TigerPawd   Groupie   Joined: 04 Feb 2015 Location: Corpus Christi Online Status: Offline Posts: 68 |  Posted: 20 Jun 2016 at 7:46pm |
   I used hinges and for just the reason you mentioned.  They were easy to install and three 2" hinges support a fairly heavy chunk of particle board pretty well.  There are some goodies down in the floor, so if you have small ones, you would have to be sure to keep them away.   We don't have that worry, but I still gave some thought to installing a barrel bolt or magnetic catch, just in case someone was fooling around where they shouldn't be. Didn't spot a good place for that anyway, and I don't want to create an additional problem when we went to close the slide out.... | |
     Joan, Jerry and the two Pugs
 2015 R-Pod 179 | |
| StephenH   podders Helping podders - pHp     Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6463 |  Posted: 20 Jun 2016 at 10:13pm |
   The reason I would want two-way hinges is for the occasions where I forget to move something out of the way when closing the slide-out. One way hinges set for opening the slide-out would be a bad thing in that situation.
| Post Reply   |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
