  New Posts New Posts RSS Feed: LP gas indicator
Topic ClosedLP gas indicator
CharlieM View Drop Down
Direct Link To This Post Topic: LP gas indicator
    Posted: 10 Jun 2016 at 12:21pm
We techies do both. Two tanks/autoswitch/ultrasonic. Got to have something to play with! Smile
Direct Link To This Post Posted: 10 Jun 2016 at 12:23pm
Darn it Charlie, I thought I had finally found something that I could disagree with you on!
Direct Link To This Post Posted: 10 Jun 2016 at 12:35pm
Keep trying, David. It keeps me on my toes. Wink
Direct Link To This Post Posted: 10 Jun 2016 at 1:12pm
You don't make it easy!
ron/roscoe View Drop Down
Direct Link To This Post Posted: 10 Jun 2016 at 1:53pm
Ok, where do I get a steak saver adapter, how much?
Ron Rowland
Direct Link To This Post Posted: 10 Jun 2016 at 4:23pm
I disagree with you Charlie. The hot water method is very easy and very reliable, provided there is enough of a temperature differential in the hot water and the ambient temperature. IOW, it works quite well in winter. I'm not so sure about the desert southwest in summer though. When we went to visit out daughters in Nevada and Arizona last winter, I used the hot water method. It was obvious where the liquid line was. I could feel it as the tank above the liquid level would be warmer than the tank below the liquid level.
Also, if a lot of propane is being used, simple high humidity can indicate the level. I've seen the condensation at the liquid level and below on my BBQ grill. I didn't even have to pour hot water on the tank. Smile
sailor323 View Drop Down
Direct Link To This Post Posted: 10 Jun 2016 at 5:28pm
https://www.amazon.com/Steak-Saver-Adapter-Propane-Connector/dp/B00KYDJ694/ref=sr_1_2?ie=UTF8&qid=1465593809&sr=8-2&keywords=propane+steak+savAlser
also available at Camping World, sometimes at Harbor Freight.
Direct Link To This Post Posted: 10 Jun 2016 at 9:08pm
Question?  How the hell did all the good people in this forum get soooo smart?
Ron Rowland
Direct Link To This Post Posted: 10 Jun 2016 at 9:17pm
WE broke a lot of stuff.
PilotPodder View Drop Down
Direct Link To This Post Posted: 10 Jun 2016 at 9:44pm
