  New Posts New Posts RSS Feed: Dinette Trim End Issues
Topic ClosedDinette Trim End Issues
Kantuckid View Drop Down
Direct Link To This Post Topic: Dinette Trim End Issues
    Posted: 14 May 2016 at 1:08pm
My lightly used 177 has the trim loose on the end of the dinette seat. I've seen one modification here where they built a whole new end with a shelf.
 I'd prefer an easier fix:
Will this trim piece stand up to light adult use if I simply replace the current wood screws/adhesive I see now (located under the trim piece & trim buttons) with machine screws and use fender washers inside the storage area for better retention?
Obviously ones butt drags against this raised edge when getting up from the seat.
Thanks for your thoughts.
Mountainrev View Drop Down
Direct Link To This Post Posted: 14 May 2016 at 3:50pm
We felt that the trim was too thin to hold up to much wear and tear, regardless of the fasteners.  It feels like either cardboard, or at least very skinny plywood.  This is the route we took:
2014 177
Q7-retired View Drop Down
Direct Link To This Post Posted: 14 May 2016 at 4:14pm
Beautiful work!  Did you reinforce the structure inside the bench to hold the new wood?  Angle fasteners against the wall?
Best regards, Jim
2015-RP178
TV 2015 Audi Q7 TDI and 2017 Ford F150
At home in "Our Pod"
Direct Link To This Post Posted: 14 May 2016 at 5:05pm
Wish I could take the credit, but a friend did the woodwork.  He did not reinforce the structure, but screwed it into the existing wooden framework on the bench and used angle irons on the top, I believe.
2014 177
Pod People View Drop Down
Direct Link To This Post Posted: 14 May 2016 at 6:08pm
We made an entirely new end trim piece and also remodeled the end of the storage compartment on our 173. We built a double shelf for shoes
Vann & Laura 2015 RPod 179
M0tl3y View Drop Down
Direct Link To This Post Posted: 15 May 2016 at 12:33am
I did this similar mod myself, but only because of my personal preference. I've read several posts where people have completely removed the existing, flimsy, end-pieces and their cushions stay in play just fine.
Some have removed them and put velcro under the cushions to keep them in place.
I'm pretty sure you can do about as easy-a-fix as you'd like and you'll be happy with the results since there's been so many solutions by so many people and everyone seems to be happy with their version of the mod.
The 178 club
Direct Link To This Post Posted: 04 Jun 2016 at 10:03am
I took the lazy/easy route for now and drilled clearance hole through the snaps to allow a small machine screw instead of wood threads that had pulled out. I'm a lifelong woodworker and may do something fancier later. I dislike anything that encroaches on the entryway of my 177 pod. Thanks for the replies!
