 Post Reply Post Reply Page  <1 4647484950 88>
Marco T View Drop Down
Post Options Post Options   Quote Marco T Quote  Post ReplyReply Direct Link To This Post Topic: Pictures of tow vehicles and trailers
    Posted: 08 Apr 2016 at 12:54am
The snow finally melted so I was able to hook up our new tow vehicle to our rpod this past weekend!  It'll chug a lot more gas, but it's so much nicer towing with the Durango than it was with the Sienna.  We took it for a little spin and then re-positioned it in the yard on some flatter ground so we can try out the r-dome this weekend.
The Tri-podders
2011 Dodge Durango Citadel - 5.7L Hemi
2015 R-pod 176T
Capt Kidd View Drop Down
Post Options Post Options   Quote Capt Kidd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 1:01am
Good looking rig! What kind of gas mileage do you get with the Durango?
We towed behind my sisters Honda Pilot and at 57 mph o\n flat level ground at sea level we only get 11 mpg.
So I will tow behind our Dodge 3500 MegaCab diesel which got 13 mpg going up into the mountains.
The Pirate's Pod
Post Options Post Options   Quote Marco T Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 1:38am
I've only towed around the block, so I can't comment on the mileage yet, but we expect it will probably be in that same range.  Without the rpod we're seeing 15-18mpg, so 10-12mpg or even a little less wouldn't surprise me.  I think I read somewhere on these forums about a guy who sealed off the bottom of his rpod to reduce drag and he saw a significant improvement in fuel economy.  I may see if I can find some appropriate material and try to do the same.  Worst-case scenario is it would protect the tanks from road damage.  If I can get 15% better mileage it's worth a try.
The Tri-podders
2015 R-pod 176T
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 6:36am
Looks good!  Where are you located in this great land?  We hope to be where you are soon, can't get to ours yet, too much snow and mud to get to the horse barn on the back 20.  Forecast is for more snow for the next few days.  Hopefully by middle of next week we can get into the 40 degree range.
Seems like regardless of the TV, towing with the pod will cut your mileage in half, the usual mileage as you read the myriads of posts is usually between 10 - 13 mpg.  Keep us updated on what you get with your rig. Thanks
Patriot Dave View Drop Down
Post Options Post Options   Quote Patriot Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 6:10am
Ford Ranger, one of those models that came with a half ton rating.
Dave & Joyce
Post Options Post Options   Quote Leo B Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 8:19am
Looks great!
Previously owner
Ron View Drop Down
Post Options Post Options   Quote Ron Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2016 at 3:09pm
Ron rowland
Ron View Drop Down
Post Options Post Options   Quote Ron Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2016 at 3:19pm
Question?  My 2016 RPOD 178 came with an Rdome.  One of the parts to set up the  Rdome is a 18 foot piece of screen attached to a rubbr insert to keep bugs out.  The screen is about 15 inches in width and 18 feet long.  How do you attached it to the RPOD just using the rubber and Tracks?  Seems like I should have a weighted bottom on the screen.  Does the step have to be retracted when using the bug screen?
Ron rowland
Ron View Drop Down
Post Options Post Options   Quote Ron Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2016 at 3:21pm
Please see my post today about the Rdome.  Need help!
Ron rowland
dacolson View Drop Down
Post Options Post Options   Quote dacolson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2016 at 3:36pm
The steps need to be retracted on our 172T. I made several cuts in the screen however to allow it to hang straight around the axle and the steps. On the whole, we don't use the skirt bug screen often anymore. Too many other places to allow bugs in. Instead, we burn citronella candles inside the rdome. Seems to work well enough.
Dave - 2016 Silverado 2500HD LML - 2010 RP172T
