Retroactive
Topic: GFI house breaker Posted: 30 Mar 2016 at 10:09am |
Have you checked to make sure you do not have any wiring issues in your house? I have owned a few houses that have had some previous remodeling, that there were mistakes in the wiring which were not obvious - until weird things like plugging in a satellite receiver for the TV. The older the house, the weirder it can get. A nice thing to have handy is a an outlet circuit tester:
Retroactive
Posted: 30 Mar 2016 at 10:12am |
Originally posted by Retroactive
Yes. Any hardware store should have them. Just make sure to find at least a 20amp rated one, since that is what the RV shore power adapter is rated for. |
The shore power plug is rated for 30 amps. If the current circuit breaker is rated for 15 amps, stick with a 15 amp outlet. |
Good point, I didn't think about the house circuit breaker rating.
JandL
Posted: 30 Mar 2016 at 10:54am |
I would check the duplex outlet on the exterior of the trailer and make sure it doesn't have mosture in it. Also in my trailer the cabinet under the sink has 2 electrical connectors. They are flat plugs. You should check and make sure they are dry and clean
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
mesamie
Posted: 30 Mar 2016 at 12:02pm |
seems, so far, the culprit is the $2 adapter !! Swapped it out, no trip. Turned on electric Fridg., no trip
Posted: 30 Mar 2016 at 12:35pm |
Originally posted by mesamie
seems, so far, the culprit is the $2 adapter !! Swapped it out, no trip. Turned on electric Fridg., no trip |
Good. was it the little yellow puck style? we have seen issues with them..
mesamie
Posted: 30 Mar 2016 at 3:07pm |
no, it was the little black triangular that the dealership thru in...now I know why !! Ran up to Camping World and got a circular one..who knows what the difference is.
mesamie
Posted: 30 Mar 2016 at 3:09pm |
thanks for all of the tips from everyone !!
