Privacy Curtain Mod
Tools: Measuring Tape, Pencil, Scissors.
Materials: Curtain Panel, Tension Rod, Command Hook, Command Strips, Velcro “One Wrap”.
Skill: Novice
Time: 1-2 hours
1) Pick a height for the rod. I recommend at least 3” higher than the tallest person, YMMV. Mark the height on both sides of the hallway, making sure to mark the corners of the wall - as this is the strongest point, see Fig1.
2) Cut command strips to approx size of the rod end caps. Place on wall at height marks, making sure to only place them on the corner…see Fig1 again!
3) Expand tension rod to width of hallway at height marked in step 1, and make a pencil mark at the rod joint. Now make another mark by extendeding the rod ½” longer, align and hold the joint in place and tighten screw. See Fig2.
4) Peel off paper off the mounted command strips.
5) Slide Curtain onto rod.
6) Compress rod and carefully install it so the ends contact the command strips. Note: this will take good hand and upper body strength, to get it placed correct the first time.
7) Pick a spot for the command hook.  I put it fairly high so I don’t catch it with my shoulder, but I think this would definitely come down to personal choice. See Fig3.
8) Cut Velcro “one wrap” strips to length, to secure curtain as desired. An important thing to keep in mind, when deciding on the location of the wraps, is not to block the thermostat with the curtain - otherwise it will not sense the actual cabin temp. Three strips seemed to be a good compromise, and allows it to be pulled away from the thermostat. see Fig4.
9) Yay!… see Fig 5.
L
