shroomer
Topic: Solo hitching Posted: 30 Dec 2015 at 5:57pm |
When all else fails, you look through the garage for scrap. I used a piece of cardboard to make a tube to fit over the jack post. I put a piece of styrofoam noodle into it. Now I had something to aim at. Next I clamped a 24" bar clamp onto my tailgate (with a 2x4 spacer). When the end of the bar clamp touches the noodle, I'm in position. But mostly I just use the outside mirrors and good estimation.
marwayne
Posted: 30 Dec 2015 at 5:00pm |
I painted the tip of the hitch it is easier to see with the backup camera
john in idaho
Posted: 30 Dec 2015 at 3:05pm |
How ever the dots are not perfect. About every 5 or 6 times I must make 10 trips back to look at things before I can lock the ball. The receiver that came with my '15 179 is a bit touchy. You really have to check to make sure the ball is seated on top of the ball lock.
Posted: 30 Dec 2015 at 1:34pm |
Dang you guys are quick on the draw. I went back to edit my post and have two replies. See what I said about the size of the dots.
ron_whitt
Posted: 30 Dec 2015 at 1:27pm |
I like the dot on tv and tt never thought of that. Once in a while I have to hook up solo, so this sounds like something to look into.
Ron & Shirley
2020 Tacoma
2012 177 rpod
john in idaho
Posted: 30 Dec 2015 at 1:24pm |
I line up the dot with the handle of the lift window on the back of the topper on the pickup.
Posted: 30 Dec 2015 at 1:15pm |
Originally posted by john in idaho
Put a dot or piece of tape on the exact middle of the trailer front wall so you can see it with your inside mirror. |
Hmmm, I could see taking this one step further and emulating what those hitching systems do. Put a dot on the trailer and on your back window, so from your perspective as you look through the rearview mirror they line up perfectly when the ball is under the hitch (before the hitch is lowered). There may still be issues lining up the dot on the vertical axis if the hitch is higher than normal or if the trailer and TV aren't level with each other. The horizontal axis will be more useful. And it won't help with figuring out the Z-axis (distance), but the suggestion above about taking a mental picture will get you close on the Z. Maybe if you made both of the dots appear to be the same size when everything is aligned that will help you judge the distance.
I'm going to try this!
john in idaho
Posted: 30 Dec 2015 at 10:32am |
Posted: 29 Dec 2015 at 6:52pm |
Put me down for Solo Hitch. Normally I only have to get out once and sometimes move the tongue over a little bit. The magnets don't fit perfectly on the trailer, but can get close enough to hitch.
2011 R-Pod 177
2010 Ford F-150
dogsintow
Posted: 29 Dec 2015 at 5:12pm |
thank you all so much for the ideas and recommendations. the getting-in-out gets frustrating to me. I always have my dogs with me and they ride in crates and I have to have them in the TV before I'm hitched up and they get really confused and stressed out with the repeated in/out etc. Plus in the PNW it rains a lot obviously and I've gotten quite wet just getting aligned. So I'm willing to spend a little on a good system that will help me out. It looks like there are a few good options.
2011 R-Pod 177 aka The Pawd Pad
2002 Chevy Tahoe
2 happy dogs
