diagdad
Calendar Event: winterizing - battery Posted: 10 Nov 2015 at 11:38am |
I have a R-POD 178. I finished winterizing the trailer. I disconnected the negative terminals from the main 12v battery. I covered the R-POD with a cover I bought from Amazon. It covers the battery case as well. Is it ok to leave the battery in its case for the winter or should I remove it and put it in the cellar or garage?
What do you do?
Thank you
Ken
CharlieM
Posted: 10 Nov 2015 at 2:03pm |
The battery can stay outside all winter, but it will need checking and/or recharging every 2-3 months to avoid damage. The battery is not likely to freeze, but it should not be allowed to remain in a mostly discharged state.
Posted: 10 Nov 2015 at 6:28pm |
yup, the cold weather will actually extend its life. Recharge every 2 months when it is cold, every month when it is warm.
hogone
Posted: 11 Nov 2015 at 8:11am |
hogone needs clarification!! just to confirm, one disconnects the negative terminals for winterization, not positive (or the lead positive for two batteries? I get so  . hogone
Jon & Pam
2025 GD 17MKE
2013 RP177(sold Nov 25)
2023 F150
2017 HD Streetglide
CHEESEHEAD
diagdad
Posted: 11 Nov 2015 at 8:22am |
Leaving the battery connected will drain the battery over time. This is because certain devices like entertainment center and carbon monoxide detector will slowly drain the battery. Disconnect the negative side removes the battery from the circuit. You can remove the positive but it will not gain you anything if the negative side is disconnected. The reason for negative and not positive is to disconnect the ground. If the ground is connected and the disconnected positive terminal wires touch something grounded it will cause a shot circuit which could lead to a fire or kill the battery.
CharlieM
Posted: 11 Nov 2015 at 9:09am |
For a single 12V battery or two 6V batteries in series it is only necessary to disconnect one lead. It is slightly preferable to disconnect the negative since the loose positive could contact the trailer frame and cause a problem, but only if the converter is plugged into shore power. For two 12V batteries in parallel it is best to disconnect all (2) wires from the negative battery terminal that has the wire from the trailer connected to it. The idea is that both batteries be completely disconnected electrically.
diagdad
Posted: 15 Nov 2015 at 10:07am |
Has anyone tried to leave the battery connected and plug the R-Pod into the house with the hot water heater off for the entire winter?
This will keep the battery trickled charged.
Any draw backs?
If so What would you suggest is a good cheep trickle charger I could connect the battery to outside the R-Pod?
Thank you
Ken
Guests
Posted: 15 Nov 2015 at 11:30am |
It should be fine. Mine is like that now.
The WFCO converter unit has a built in 3 stage charger. My batteries have suffered no ill effects by leaving the unit plugging into the house all winter. In fact, my camper is plugged in all summer too, except when I'm on the road.
