  New Posts New Posts RSS Feed: More Newbe questions
Topic ClosedMore Newbe questions
Idaklee View Drop Down
Direct Link To This Post Topic: More Newbe questions
    Posted: 28 Sep 2015 at 11:27pm
Two questions tonight: there's a sign on my 177 that says "check and maintain all seals every 90 days". What?? Seals where? 2nd question: two ways to add fresh water...hooking directly to the Campground faucet bypasses the tank?? So if I want water during the trip for short stops, I have to put fresh water in the place above, using a funnel? Is this right??
thanks!!!
Marcia
Marcia from MN
13 177 R Pod
06 Dodge Grand Caravan
Max, Gracie & Greta
GLBCamper View Drop Down
Direct Link To This Post Posted: 28 Sep 2015 at 11:53pm
I have been wondering the same thing about the seals, so hopefully someone else will chime in. As to the water, you are correct. "City water" bypasses the tank. Most people use this little item that connects to their potable water hose to fill the fresh water tank. (About 4 bucks on Amazon) search "water tank filler"
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Direct Link To This Post Posted: 29 Sep 2015 at 12:38am
Thanks! I'll order one.
Marcia from MN
13 177 R Pod
Max, Gracie & Greta
kindell View Drop Down
Direct Link To This Post Posted: 29 Sep 2015 at 5:42am
Watching a couple of intro to the 179 videos, they say the water heater can be gas or electric. But when we contacted our dealer about it and how to switch over he said NOPE, GAS ONLY. Tonight I watched another video on the 179 and again the dealer said it was gas or electric. Since we're not getting any assistance from our dealer, maybe someone here in the Forum can help us figure this out.
Art & Kindell
Cooper the Super Dog
2017 Keystone Bullet 265
2013 Chevrolet Silverado 1/2 ton
Former 2015 RPod 179
HuronSailor View Drop Down
Direct Link To This Post Posted: 29 Sep 2015 at 7:55am
Go outside and remove the water heater cover. There's a little rocker switch in the lower left hand corner, partially hidden. It may or may not have a small cotter pin through it. Pull the cotter pin and turn the switch on. Make sure the water heater is full of water beforehand, and remember to turn the switch off before you empty the heater. Not the most convenient setup but that's it. Some people turn the switch on and then use the breaker as a switch. Myself, I added a switch with a pilot light to the inside of my pod.
wingnut2312 View Drop Down
Direct Link To This Post Posted: 29 Sep 2015 at 9:10am
I think some people refer to them as gaskets (?). Basically, you want to use a protective/lubricating spray on the flexible rubber tubing around the main door, pass through storage doors, slide out, garage (if you have one) and anywhere else they are. If you don't maintain them, they can dry out and crack causing them to need replacement.
I'm not great at the 90 days part, but I do it at least once a year. Takes maybe 20 minutes. Just spray it on directly or onto a rag/paper towel and whipe it on. Should look wet, but not dripping.
2014 rpod 182G
Ford Expedition
ronahue View Drop Down
Direct Link To This Post Posted: 29 Sep 2015 at 9:11am
I spoke with a "Forrest River Rep." at the Hershey show last week and ask about the inspection of the seals he said it has nothing to do with the rubber seals but refers to the silicon sealant at the conners of the exterior. I'm not sure I believe him it just doesn't make sense. My dealer says it just means check the door and slide seals. Take your pick.
It's a lot like asking how you should jack the unit up to change a tire they will tell you what you can't do but not what you can do.
Ron & Sharon
2015 R-Pod 179
2022 Nissan Frontier
Direct Link To This Post Posted: 29 Sep 2015 at 10:53am
Direct Link To This Post Posted: 29 Sep 2015 at 12:36pm
Could you please give us the brand name of the protective lubricant you use on the gaskets?
Marcia from MN
13 177 R Pod
Max, Gracie & Greta
Direct Link To This Post Posted: 29 Sep 2015 at 12:45pm
I'll have to look when I get home. I believe it was this http://m.lowes.com/pd/Blaster-11-oz-Silicone-Lube/3653299. I'll check and repost if necessary
2014 rpod 182G
Ford Expedition
