List Your Mods: |
Page <1 3738394041 78> |
![]() ![]() ![]() ![]() Posted: 05 Aug 2015 at 8:53pm |
Two new identical batteries will not asymmetrically discharge, no matter if they are in series (6 volt) or parallel (12 volt)...as far as I know. I understand your logic, just want to make sure we pass along good info. fred
JandL ![]() Senior Member ![]() ![]() Joined: 29 Mar 2014 Location: California Online Status: Offline Posts: 364 |
Solar Panel cost
I am adding a price list to the solar panel installation I did my trailer Manual reset circuit breaker 10 amps Bussmann #25510-B-2 $15.78 (Waytek Inc.) Attwood marine Large Battery Box #9084-1 $22.57 (Amazon) Parent Units 2 Pack Topple Stop Furniture Straps $15.66 set of 2 (Amazon) Solar Pv Cable - 30ft / 12 AWG - Mc4 Solar Photovoltaic Copper Conductor Cable $17.00 (Amazon) Camco Gray Party Light Holder # 42693 $6.48 Pack of 7 (Amazon) Quick-Grip 4-Inch Handi-Clamp 59400CD $8.00 ea. 2 req. (Home Depot) Morningstar SK-12 SunKeeper 12 Amp PWM Charge Controller 12 Volt $79.60 (Amazon) Group 27 Battery #12852 $86.99 (Costco) Grape Solar 100 watt panel #773274 $139.00 (Costco) SB50 SB Series 50 Amp Anderson Powerpole Kit #SB50-10-RED $3.08 ea 2 req. (Powerwerx) Dust Cover for SB50 Amp Series Housings #DUST-SB50 $3.49 (Powerwerx) Safety Boot for SB50 Amp Housings # Boot-SB50 $3.29 (Powerwerx) Total cost $408.94. If you take out the battery and battery box because everyone is going to need a battery and box or may have them already, the cost is $299.38 |
JandL
2013 Honda Ridgeline 2012 177 2 Paynes in a Pod |
I went with the single battery for simplicity. The problem with multiple batteries is after a while one would get weaker and the stronger battery would discharging into to the weaker battery to try to bring it to the same voltage. I would have purchased a group 31 but Costco doesn’t carry them. Someday when I have to replace it I will go to Sam’s Club because they carry group 31 batteries. Any battery bigger than that, I would need a forklift to lift it in place. I also have a generator, but the solar panel makes no noise.
JandL
Sounds great, ilthyn! I gotta ask though, why not just run an inverter on your Ram 1500?
JandL, really well thought out and engineered, but I gotta ask...have you considered more storage, i.e. dual 6 volt GC batteries? I get at least 4 days out of my duals (230 amp/hr) and then I'm either back on the road or using my yammy 2400 to bring them back up. I love the idea of solar, but have a hard time justifying when I can go a month on a gallon or two of gas....for now. fred
ilthyn ![]() Groupie ![]() ![]() Joined: 21 May 2013 Location: Alberta Online Status: Offline Posts: 66 |
Nice mod with the solar.
I have a 120 watt mounted on top of my truck. It is on a garage door sliding frame so it can be mounted and removed easily on the wheels. It also tilts to the proper angle for maximum sun angle. The plywood slab it sits on can be raised and acts as a slipstream deflector ( not needed so much now as my Ram 1500 outperforms my old Dakota, but on long trips it is significant.) I also have removable cross pieces so I can tote long objects. (Portabote in my future). The panel charges an Eliminator batteryunit which outputs 12v DC and fairly limited 110v AC. It will run my circular saw. ilthyn
Tri-Pod ![]() Senior Member ![]() ![]() Joined: 17 May 2011 Location: Liberty Hill Online Status: Offline Posts: 112 |
What a well thought out plan and you seem to have thought of everything. Great explanation on your project anyone here could do the same by following your instructions. wOW. I couldn't handle the engineering and broke down and bought a Honda eu3000s. Which keeps the wife happy when the AC is running but the we are in Southeast Texas where to day it is 97 feels like 105 with the humidity. But back to your project so nice thanks for sharing it with us.
2013 SP 240 w outside kitchen 2012 Toyota Tundra Crew Max 4x2 5.7L V8 Me, My Honey, and Max our GSP |
Falcmerlin ![]() Newbie ![]() Joined: 26 May 2015 Location: UP Online Status: Offline Posts: 3 |
great idea thank you
Looks good. I like the reminder tag, I do the same when I put the jack down at truck stops and Wal-Marts so I don't forget.
Solar Panel
I purchased a Grape Solar “GS-Star-100W”, 100 watt panel from Costco and a group 27 battery. I had to get a new battery box to hold the bigger battery and to also mount the charge controller and circuit breaker. The charge controller is a Morningstar “SK-12 SunKeeper” 12 Amp PWM Charge Controller. They make a 6 amp model but someday I may want to add a second panel so I got the 12 amp. To hook it up to the panel and battery I used an Solar Panel Cable - 30ft long, 12 AWG wire, with Mc4 connectors. I cut the cable in half and attached it to the Anderson multipole power connector, SB50 series, 50 amps, 10-12 gauge wire contacts and added a dust cover along with a Bussmann 10 amp panel mount circuit breaker “25510-B-2”. I carry a step ladder in my rear pass thru hung from a wood slats. I need the ladder to install the panel. The solar panel travels in my bathroom strapped to the wall; it’s not a problem if it gets wet. I haul everything out to the side of the trailer and extend the 2 legs that are attached to the panel with hinges. The panel weighs 20 pounds so it helps to have some hand it up to you. I have installed foam strips to the frame of the panel so it won’t damage the roof or edge molding. I use 2 Irwin Quick Grip Handi Clamps to attach the legs to the slide out frame. I trimmed off the ends of 2 Camco Party Light Holders and super glued them together to so I could attach the cam from a “Parent Units 2 Pack Topple Stop Furniture Straps” I got from Amazon. The straps I attached to the side of the solar panel. I put a lock on the Handi Clamp to make it harder to remove the panel; the back tube on the lock was to increase the diameter so you can’t operate the release mechanisms on the clamps. I route the wire down the side of the trailer to clips, I have replaced most of the plastic ones with metal one because the plastic ones snapped off. If shade is covering the top of the trailer I can position the panel on the ground. Group 27 battery and charge controller wiring Charge controller, Anderson connector and circuit breaker Ladder storage Secured in the bathroom for travel All the parts and the installation Lock to make it harder to remove and straps to help hold it in place if there is wind Because it is not bolted to the roof I can move it to get the best sun Warning label so you do not run the slideout Mt. Rose Campground last Thursday had good sun so the battery's charged, on Friday their was over cast so it didn't charge as well |
JandL
sailor323 ![]() Senior Member ![]() Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
In Windows Live Photo Gallery, in the upper left hand corner, click on "organize, edit or share" Choose edit and then choose the size--medium works well for sharing on FB. Click that and save.
