Calendar Event: LED Light dimmers Posted: 22 Dec 2015 at 6:19pm |
Sounds like no extra circuitry in your flashlight, but that makes sense since the voltage will remain in a defined range. Charge cycles on a lead-acid battery can send voltages over 15 volts so it makes sense to limit that, or the voltage can go down to 11 volts so it makes sense to boost that to maintain the light output.
Each light has its own switch so each one would need a pot in the correct ohm range.
Harper
Posted: 22 Dec 2015 at 3:08pm |
I know the ones in my flashlights don't put out the same lumens until the batteries die; they get dimmer as the batteries get older. I'd be happy to swap out my LED's for that kind if I knew where to install the master potentiometer.
“The Road goes ever on and on
Down from the door where it began.
Now far ahead the Road has gone,
And I must follow, if I can..."
~ J.R.R. Tolkein
Posted: 22 Dec 2015 at 12:12pm |
Depending on how the LEDs are driven, you might be able to use a simple potentiometer to dim them (somewhat), or you may not be able to dim them at all (unless you replace them, or modify them). Some LED packages have boost/trim electronics on them which will prevent them from being dimmed.
Harper
Posted: 22 Dec 2015 at 11:55am |
They should be bright, but why is it better that bright be the only option? I personally like long talks over drinks in comfortable light. Is there no place where a master dimmer could be installed?
~ J.R.R. Tolkein
Guests
Posted: 01 Aug 2015 at 7:49am |
Here is a link that works:
podenvy
Posted: 31 Jul 2015 at 2:24pm |
If you don't mind killing the warranty on your factory LED lights and doing your own wiring/caulking, there are quite a few camper dome 12v LED with built in dimmers on Amazon.
Green LongLife 9090101 LED Dome Light Fixture Single 921 Wedge 230 Lumens 12v or 24v Natural White by Ming's Mark Link: http://amzn.com/B007SYRZH2
2013 FJ Cruiser + 2015 rpod 179 HRE
CoastalCal
Posted: 29 Jul 2015 at 10:33am |
You can replace them with "warm white" LED bulbs.....I believe from Amazon.
2015 178 R-Pod
Ford F-250 4x4 Diesel
2014 Indian Vintage
2010 HD Ultra Classic
Grandpa Hiker
Posted: 29 Jul 2015 at 9:46am |
I like the bright lights in my 179 also. I guess it must be my old eyes that need the bright light!!
BTW, my understanding is that not all led light bulbs can be dimmed.
Rob & Becky
2015 R-179 Pod aka Piddle Pod
Leo B
Posted: 29 Jul 2015 at 8:39am |
I am with ya Sailor! Really like the brightness of our 179 lights.
Previously owner
sailor323
Posted: 28 Jul 2015 at 11:08pm |
I'm sure that I'm in the minority here, but I love the lights in our 179. Yes, they are bright, thankfully.
