  New Posts New Posts RSS Feed: RP-179 slideout
Topic ClosedRP-179 slideout
lamarkeiko View Drop Down
Direct Link To This Post Topic: RP-179 slideout
    Posted: 20 Feb 2015 at 12:25pm
On my original post, I mentioned that the person doing the walk through with me stated that I could pull the R-Pod with the slide extended.  Nobody comented on this specifically, but in a stuck open slide situation, could this be done without damage?
Lamar
Podster View Drop Down
Direct Link To This Post Posted: 20 Feb 2015 at 12:33pm
Check techntreks initial response, no...you should never ever move the POD with the slide out. The slide room and POD frame are not designed to handle the forces that will be generated by the acceleration and breaking and turning and going over railroad tracks...etc.
Cliff & Raelynn
Ranger 4.0/178
TigerPawd View Drop Down
Direct Link To This Post Posted: 20 Feb 2015 at 3:00pm
Hmmm.  Looking at those pictures of another #179, that slide-out control box is in a different place vs ours.  On ours, the box is behind the fridge panel (as mentioned above), so it can be accessed with the slide-out in or out.  Sounds like someone realized that inside that hassock thing isn't a good plan.  FYI, ours is among the first of the 2015 run (June 2014), but has the slightly older color scheme.  It appears the control box change was made fairly recently.
Incidentally, that roundy section in front of those hassock thing is a fine place for john paper - just be sure you have a spare roll available in case your slide-out is stuck in....
Joan, Jerry and the two Pugs
2015 R-Pod 179
Direct Link To This Post Posted: 20 Feb 2015 at 7:00pm
I did in my first reply to you.   It was part of the reason I suggested you find a new dealer for service since they suggested that you could.
Direct Link To This Post Posted: 20 Feb 2015 at 8:33pm
techntrek, Your right.  I looked back at your post.  I think I may have missed the comment because of the separation of that line from the part about looking for a new dealership.
Lamar
mrharrybay View Drop Down
Direct Link To This Post Posted: 31 May 2015 at 10:01am
So looking at these posts I can assume that manual slide operation is not done with a crank, as indicated in my generic owners manual?
kymooses View Drop Down
Direct Link To This Post Posted: 31 May 2015 at 11:47am
Nope.
Direct Link To This Post Posted: 31 May 2015 at 2:00pm
No hand crank on the 179 Schwintek slide.
Cliff & Raelynn
Ranger 4.0/178
shortstrike View Drop Down
Direct Link To This Post Posted: 31 May 2015 at 4:04pm
I would really like to know who your dealer was?  I'm getting a lot of great information out of this post but my guess is that we would be talking about something else if your dealer knew what they were doing.
I am planning to purchase a 179 in Oregon late Summer or early Fall of this year.  I would like to know which dealer to avoid.  I know in Southern Oregon there aren't many.  It would probably be more appropriate to post your dealer comments in the "Dealer Reviews and Comments" section.  Either way, I for one, would like to hear what you have to say.  Thanks and good luck.
Direct Link To This Post Posted: 31 May 2015 at 9:23pm
Welcome.
