Page <123> |
headcold
Joined: 13 Nov 2013 Online Status: Offline Posts: 125 |
Topic: R-Dome flimsy?Posted: 11 Nov 2014 at 10:18pm |
During an July Pod trip on to the Beartooth Plateau (MT), my R-Dome
offered
merciful protection for three other parties and myself from the swarms
of mosquitoes. It was the first time I took the Dome out of the bag.
However, in the course of the trip, the Dome ripped in several places:
on the the netting which rests on the steps and in the left-hand, upper
corner that attaches to the Pod. The suction cups were of marginal use,
so I rigged what you see in the picture.The rope rigging worked better
than the cups, which have an annoying habit of popping off with the
drastic temperature swings and winds common on the Plateau. I ended
taking the ripped Dome to a local tent-maker who sewed up the rips and
sewed in patches of nylon ballistic cloth.. We'll see how that works
next year. It's -11F here this evening so there won't be any more
podding for a few months.uploads/2390/domeaid.pdf
johnandwendee
Joined: 11 Mar 2014 Location: Ontario, Canada Online Status: Offline Posts: 35 |
Posted: 11 Nov 2014 at 10:58pm |
Hi S & C,
We are not responding to your R dome comment but we noticed that you have the same Rpod (179) as us and pull it with a similar vehicle...we pull with a Honda Pilot. We have been experiencing significant sway on Texas highways and wondered if you have experienced any sway at all? We have a sway bar which we have adjusted but it has not helped a lot. Other than that....we are very pleased with our 179. Happy travels! Wendee & John |
John and Wendee
Bracebridge, Ontario Canada |
marwayne
Posted: 12 Nov 2014 at 12:50am |
I think Headcold has a 177.
As far as the r-dome, we have ours for over 4 years, no rips no zipper problems. We use it every time we camp. |
Unclewillis
Joined: 26 Aug 2014 Location: NV Online Status: Offline Posts: 101 |
Posted: 12 Nov 2014 at 2:06am |
We recently put our R-dome and tent bed (176T) to the test in the rain. The dome and tent bed withstood an all day rain just fine. We played cards underneath the dome during the rain at night. No Leakes or drips what so ever. It was great. Then the front moved through and the temp dropped into the mid 30's and the wind went away. This led to conditions ripe for dew and fog. Once the dew settled on the dome it seemed to leak alot and everything was super saturated under the dome. Had to use a broom to knock of the water before the sun came up and it dried off.
Not a huge dilemma but I wanted to throw that out there. |
Daddy, Mommy and Daughter.
BlackJack & Keno (boston Terriers) Rpod 176T 2015 Nick: ouR-pod |
Posted: 12 Nov 2014 at 8:12am |
Uncle Willis,
The dome didn't leak. It cooled faster than the more solid, and thermally stable things around it, and condensation formed on the dome fabric, inside, and out. Happens. Natural phenomena. |
Shadow
Joined: 17 Aug 2014 Location: Kanata, Ontario Online Status: Offline Posts: 24 |
Posted: 21 Nov 2014 at 8:45pm |
John and Wendee
Just read your post today Nov 20. We haven't had any trouble with sway and have pulled in some strong side/ head winds. We have the resistance sway bar fairly tight but not over done. I saw on an other post that someone had an accident with a Highlander due to sway that started on a downhill corner - a lot of discussion about using the brake controller to support driving thru. Shirley
S&C
2015 R-POD 179 2010 Toyota Highlander |
headcold
Posted: 21 Nov 2014 at 9:40pm |
John and Wendee:
I used to pull the 177 with a Toyota 4-runner (currently towing with a Toyota Tundra) and had no sway problems in the highest of winds in the wide-open spaces where I live. However, I used (and continue to use) an Equalizer hitch which kept the 4-Runner, with its relatively short wheel base, straight and level, now sway. http://www.equalizerhitch.com/ The Tundra with an appreciably longer wheel base, could probably tow without the sway/equalizer hitch and not suffer sway, but I always put on the Equalizer. Headcold
headcold
Posted: 21 Nov 2014 at 9:41pm |
I should have said "no sway" rather than "now sway." We need an editing feature on this blog.
Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9066 |
Posted: 21 Nov 2014 at 9:54pm |
Upper-right of each post, Post Options > Edit Post.
headcold
Posted: 22 Nov 2014 at 7:30pm |
Thanks. Didn't know I could.
Page <123> |
