Larry158
Calendar Event: Installing additional wall cabinets Posted: 05 Nov 2014 at 10:04pm |
Has anyone added additional storage cabinets on the wall of a R Pod 178. If so where & how did you do it?Thanks Larry158
marwayne
Posted: 06 Nov 2014 at 1:43am |
Larry158
Posted: 06 Nov 2014 at 7:39am |
Thank you for your reply. The pictures beg two additional questions. 1) are the additional cabinets homemade or storebought,2) How did you know where to "screw" into the side walls for structural support. JUst bought our 178 & doing research during the winter months for our upcoming spring first trip. Thank you for the pictures. Larry158
Podster
Posted: 06 Nov 2014 at 8:41am |
marwayne...Wow, beautiful, very nice...seriously, this is master craftsmanship level work. Impressive, it's a good thing you don't live closer because you would wake up one morning with my POD sitting in your driveway with a sign on the front that says..."Help Me!"
QUESTION: I see you used a pedestal stand to support your table, how did you mount it to the floor? Does it have other supports other than the ped? I think the floor is 0.25 ply with foam between, is that correct? I ask because we HATE our table and it must go.
Cliff & Raelynn
Ranger 4.0/178
Luv2Q
Posted: 06 Nov 2014 at 10:26am |
Beautiful workmanship. I'm envious. Sadly, I've learned that having tools hasn't made me a craftsman.  And, yes, I'd also like to know more about that pedestal table. Surely, that heavy particleboard can be replaced with a sheet of cabinet-grade ply, yes?
John & Teri
Tundra 5.7L V8 / RP 180
JStrube
Posted: 06 Nov 2014 at 10:57am |
Yeah, my biggest question with modding the pod, how do you find mount points. Like in the garage of my 181G, the track is only mounted in the corners. Not too sturdy, want to add more support in the center, don't know the structure, or where it is. Would hate to use metal screws into wood, or just screw to thin board.
2012 181G
marwayne
Posted: 06 Nov 2014 at 11:20am |
Larry, to answer ? no 1 check my tagline.
Check under mods, Cabinets page 24 and New table part 1 and 2 page 65.
I don't know how to put a link to it.
Larry158
Posted: 06 Nov 2014 at 4:43pm |
Marwane, Thank you for that lead on cabinets page 24. I saw what you did, but how did you do it? I suffer from the condition of being over tooled & under knowledged. How did you figure out where to put the ceiling support wood. Is there any support behind/up in roof to srew into? What does the tag line mean? Thanks again Larry158
marwayne
Posted: 06 Nov 2014 at 7:20pm |
Solid backing in ceiling, every strip of burlap molding has solid backing, then there is another solid strip of backing in between the burlap moldings.
The meaning of my tagline? I build my own stuff so I know it's done right.
Larry158
Posted: 06 Nov 2014 at 8:41pm |
Marwane, I am in your debt for sharing your expertise & knowledge with a "newbie". Thank you for your help. I really appreciate it. Last time I was up your way was for the Calgary winter olympics. Really had a great time. Thanks Larry158
