  New Posts New Posts RSS Feed: About to buy a 179
Topic ClosedAbout to buy a 179 - Event Date: 30 Oct 2014 - 01 Dec 2014
Direct Link To This Post Calendar Event: About to buy a 179
    Posted: 31 Oct 2014 at 11:28am
Originally posted by Trinityfly
Having the same problem with my water heater. Water was just Luke warm. Where is the water heater by pass?
The switch in the water heater enclosure is for changing from gas to electric.
A) The switch isn't for "changing", just "using" the electrical side of the WH if you have full hook ups. You use gas when you don't, BUT you can use BOTH for faster recovery time, if both are available.
B) The bypass valves are behind the WH, under whatever panel is above it. They have a summer or use setting, and a winter or bypass setting. Their purpose is so that when you winterize, you don't have to pump 6 gallons of anti freeze into the water heater before it starts to fill the rest of the plumbing.
Joe-n-Terri View Drop Down
Direct Link To This Post Posted: 31 Oct 2014 at 11:11pm
Congratulations, we just bought a 179 a week ago. I have only been able to camp one night in the driveway with the grandson but it was fun. Make sure you inquire about the extra year of warranty for $150, you only have 10 days to do it. Also while registering for warranty on the appliances dometic is offering 15% off their extended warranties and you can take them out 1,2, or 3 years on the A/C and frig. So you can get a total of 5 years on those pretty reasonable if your interested. I haven't tried my rdome yet, we have been busy personalizing but we hope to make the inaugural 1st trip next weekend at Ft Pickens Florida. Its the Blue angels Homecoming Air Show in Pensacola. Good Luck
Joe & Terri
2015 179
2015 Ram 1500 crew cab/ eco diesel
2005 Ram 1500/ Tekonsha Controller
Lovestarved Pom/Demanding Chihuahua
gkooris View Drop Down
Direct Link To This Post Posted: 01 Nov 2014 at 12:42pm
Thanks, everyone. I'm keeping this as a reference when we get to Couch!
When in doubt, go strong and wrong
Trinityfly View Drop Down
Direct Link To This Post Posted: 01 Nov 2014 at 12:57pm
About possible cold water intrusion to hot water stream. Contacted tech support because couldn't locate the hot water heater bypass. Bother, it is located behind the water heater and under the bed support on the 179. Not at all convenient. the bedding and mattress must be removed an then the bed support has to be unscrewed from the frame to access the bypass. When I asked why the heck would it be in such a ridiculously difficult to reach place the answer was, "because they don't want users to use the space as storage". Tech support said that it happens all the time. Ugh! Still haven't decided whether I should do it my self or require the dealer to do it. Really stupid to leave the valve opened on a brand new trailer.  Angry
Joe and Diane, pups Jenny and Tyke. RPod named Lilly.
Alive and well deep in the toolies of Norther Calif
Direct Link To This Post Posted: 01 Nov 2014 at 9:42pm
It is like the 171.  The solution I've used for years - unscrew the plywood and leave the screws out permanently.  Then lift the mattress and support it with your back while you shift the plywood out of the way.  Then you can reach down to turn the valves.
Direct Link To This Post Posted: 12 Nov 2014 at 11:35pm
Update - placed our deposit with couch today for a new 179 with the Pebble interior. Hoping to drive from Connecticut to Ohio the first week in December. We're pumped!
Thanks for all the info,
Geoff
Podster View Drop Down
Direct Link To This Post Posted: 13 Nov 2014 at 6:51am
Congratulations on the new 179!
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 13 Nov 2014 at 7:32am
Hope you enjoy your new 179 as much as we enjoys our!!
Previously owner
sullyd54 View Drop Down
Direct Link To This Post Posted: 13 Nov 2014 at 8:52am
hi congrats on your purchase , was there anymore room for negotiation after the email quote ?         thanks sullyd
Direct Link To This Post Posted: 13 Nov 2014 at 9:25am
None, only if you got a lower quote. We shopped this trailer endlessly. I found their price impossible to beat.
