  New Posts New Posts RSS Feed: 2010 RPod 171 Smell?
Topic Closed2010 RPod 171 Smell? - Event Date: 13 Aug 2014 - 01 Aug 2015
 Post Reply Post Reply Page  <1 234
Direct Link To This Post Calendar Event: 2010 RPod 171 Smell?
    Posted: 13 Aug 2014 at 6:20pm
We had a 2010 171 and like Moe, any odor after being closed up for the winter was gone once we opened everything up in the spring.
Direct Link To This Post Posted: 13 Aug 2014 at 6:18pm
It evaporates after time.
StrongPod View Drop Down
Direct Link To This Post Posted: 13 Aug 2014 at 6:10pm
I thought the winterizing fluid would fill the (p) traps of the shower/sink/toilet? and keep the plastic tank air from coming up through them?
kymooses View Drop Down
Direct Link To This Post Posted: 13 Aug 2014 at 5:56pm
Not using your sinks or shower, the p-traps are likely completely dry.  Might be tank smell coming up through your drains.
Granted you've not used your gray tank much but it could just be smelly plastic tank smelling air that is coming up through them.
Might want to keep the traps all filled with water to keep air from the tank from coming back up and into your Pod.
Craneman View Drop Down
Direct Link To This Post Posted: 13 Aug 2014 at 4:12pm
We to have a 2010 174, and it will develop a odor when closed up. But like you say open the door and in just a few minutes it's fine. Have never found the source and now quit looking. If you find out what the cause is let us know.!!!!!!
               Moe
Jo and Gary
2010 174
2011 Ford 150
Direct Link To This Post Posted: 13 Aug 2014 at 3:54pm
Hi all,
I bought a new Rpod 171 in 2010 and have used it for many miles and weeks of camping. I've been wanting to ask this question. When my camper is closed up it has a smell. Once it's open, I don't notice it anymore. The smell would be more chemical-like, maybe an off gassing like smell. But I would have thought after 4-5 years that smell would go away? I noticed that the next year after mine, they came out with something called "Eco" made/built, which made me wonder?.....
Let me give you some more data also:
1. I keep it meticulously clean
2. No smokers or pets have ever been in it
3. I've NEVER used the potty or shower
4. I've only hooked it up to water and used the sink twice when it was brand new
5. I've never used the hot water heater and its on bypass
6. I don't store anything in it
7. I've not added or changed anything on the interior
8. I keep it in my driveway at home and open it up and check it fairly often
9. I don't cover/tarp it
10. There are no leaks that I'm aware of
11. I don't cook food it it (I just plug in an electric skillet and coffeepot outside)
12. I always strip all bedding etc. when I return from a trip
Additional info:
1. After the first two years, I quit winterizing and dewinterizing it because I wasnt using the plumbing system so I kept it permanently winterized, which the dealer said was ok.
2. I recently flushed the entire system just to make sure there wasn't something in the pink winterizing solution that might be having a chemical smell.
I'm stymied, any thoughts from anyone (especially those who have the 2009/2010 Rpod 171 model) would be appreciated.
