  New Posts New Posts RSS Feed: Water Tank Beam
Topic ClosedWater Tank Beam
wildfire305 View Drop Down
Direct Link To This Post Topic: Water Tank Beam
    Posted: 29 Jul 2014 at 6:18pm
Maybe it's a 179 thing?
2005 Dodge Durango 4.7 V8
OLD Tow Vehicle 2004 Honda Odyssey
2015 RP179 "73b"
OLD 2005 Viking Saga 2480ST popup
COSPod View Drop Down
Direct Link To This Post Posted: 31 Jul 2014 at 10:32pm
My 2014 172 HRE has same issue, all 3 tanks door side have the gap.
Direct Link To This Post Posted: 03 Aug 2014 at 7:38am
Checked our 179 and it was all solid and tight.
trvlnlite View Drop Down
Direct Link To This Post Posted: 03 Aug 2014 at 8:06am
Checked the fresh water tank last evening and one side of the beam has at least a 1/2" gap between the plate and frame. And all three screws inserted at an angle. Freak show! StarMy hair stood on end!  Will check them all out today and fill with washers if just those few.  If they are all like this, I think I will seek more professional help. Who would have guessed?  Thanks so much for all of your posts!
Have a great day...The Michelsens, 2015-182G and Boston's x 2
Budward View Drop Down
Direct Link To This Post Posted: 03 Aug 2014 at 8:16am
Must have been a new guy that did yoursErmm
2014 179
Direct Link To This Post Posted: 03 Aug 2014 at 9:52am
Budward,
I also checked the exposed wood  spot that you found that was on both sides of the step and that was all sealed. I agree a new guy or someone who take pride in their work!! ( getting to be a rare find!!!)
Direct Link To This Post Posted: 03 Aug 2014 at 9:54am
Clearly the brackets are not the right size for the trailers, or the tolerances for them or the frame spec is way too loose.
2015 RP179 "73b"
Direct Link To This Post Posted: 03 Aug 2014 at 3:12pm
    I would think that if this was a automobile there would be a recall. With the r-pods mentioned that have problems with brackets and screws that should be of some concern for safety that Forest River would want to have the holding tanks secured properly. RV's are very different from the automobile industry.
2023 Aliner Scout Lite
Direct Link To This Post Posted: 03 Aug 2014 at 7:13pm
Several Tanks have to fall out before a recall would ever be issued. Business reputation is damaged by issuing a recall and they're not going to do it unless there is a "realized hazard" not just a "perceived hazard". The burden of proof is unfortunately on the consumer. Heaven forbid a company or person take responsibility for their own actions in today's society.
2015 RP179 "73b"
travelksjt View Drop Down
Direct Link To This Post Posted: 04 Aug 2014 at 7:05pm
Hi All my wife and i own a 2013 177. I looked under and found pretty much the samething as everyone else with a twist. My water tank and waste take only have screws in the bottom holes not the top... One of the water brackets has a twist on it to. I for the heck of it check to see if the bolts fell out of the top holes. Get this they were never drilled for bolts or anything How could FR let this go? the space for those top holes are very hard to get to. I am not sure if just replacing longer bolts in the smaller holes is enough to carry the weight. Anyone else have any thoughts on this.
Thanks
John
i pull my 177 with a 2011 four runner
