List Your Mods: |
Page <1 2425262728 78> |
Budward
Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
Topic: List Your Mods:Posted: 28 Jul 2014 at 7:51am |
Cody91- where'd you find that net? Only ones I've been able to find are either only 4 ft wide or way too wide....
TIA! |
2014 179
cody91
Joined: 12 Feb 2014 Online Status: Offline Posts: 184 |
Posted: 28 Jul 2014 at 8:40am |
Budward, I had trouble finding a net at local suppliers too. I finally found this place online called Organized Obie. They make netting solutions for RVs. Here's the link. Good luck, Cody91
GingerPod
Joined: 09 Jul 2014 Location: Pinehurst NC Online Status: Offline Posts: 67 |
Posted: 29 Jul 2014 at 11:20pm |
I just finished adding a 2nd battery....I used a Marine cutoff switch mounted directly to the Battery box. I can now isolate the battery from the camper at anytime.,But retained a permanent connection to the Zamp port so I can charge from the Solar panel at any time regardless of cutoff switch position. Also enables me to be plugged in to shore power any length of time without fear of over charging the batteries or boiling them to bits ![]() Plus I added a steel cable and lock to keep honest people honest.... ![]() |
FOUND OUR NEW-RETRO TEARDROP!!!
Posted: 30 Jul 2014 at 9:41pm |
No worries about the converter overcharging, it is a proper 3-stage charger. Also if those batteries are two 120 volt batts, you'll get more total amperage by always charging and using them together instead of one at a time. Look up Peukert Effect for techie info.
GingerPod
Posted: 30 Jul 2014 at 10:50pm |
Thanks for the heads up on the converter charger. Yeah both batteries are hooked together for use. Together also for charging,by either Solar or Convertor and of course while driving down the road. Double the available amps,both are 12V,should keep good for days dry camping! |
SuJoPodders
Joined: 02 Jun 2013 Location: Janesville Ca. Online Status: Offline Posts: 16 |
Posted: 02 Aug 2014 at 3:32pm |
Latest update on our 177 mods.
Leaving in a day for a month long trip to Alaska. Trying to make it as livable as possible. Curb side rear shelf. ![]() Street side rear shelf. ![]() Adapted shower caddy. ![]() Storage pockets moved from bathroom. ![]() Storage pocket from shower. ![]() 24" AC/DC TV/DVD ![]() View of TV from bed. ![]() Mount attached to kitchen slide out. ![]() Custom made Cribbage Table. ![]() Mounting hardware. ![]() ![]() ![]() |
jan demarinis
Joined: 22 Apr 2014 Location: Northern CA Online Status: Offline Posts: 54 |
Posted: 02 Aug 2014 at 5:12pm |
I like it! Nice work. Have a great trip.
2014 178 HRE
The Podyssey 2013 BMW X3 35i Prodigy RF Brake Controller |
Posted: 02 Aug 2014 at 8:08pm |
ditto
Tbslants
Joined: 12 Jul 2014 Location: Brunswick, ME Online Status: Offline Posts: 10 |
Posted: 04 Aug 2014 at 2:01pm |
Hi TriumphRider,
I recently purchased the 179 and have the same issue with the TV...the links for the mod would be greatly appreciated. Thanks!! Tina |
ShazG
Joined: 25 Mar 2014 Location: Wallsburg, Utah Online Status: Offline Posts: 9 |
Posted: 04 Aug 2014 at 2:20pm |
http://www.amazon.com/gp/product/B002UC6RP8/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1This is where I got mine. Amazon. Perfect fit.
ShazG
