Page 123> |
Inge
Joined: 30 Jul 2014 Online Status: Offline Posts: 34 |
Topic: Flexible Solar Panels .. any recommendations?Posted: 30 Jul 2014 at 8:28pm |
Hello There,
We would like to get flexible solar panels to mount / glue on our r-pod 182G ceiling. Did anyone here do this yet? I'm wondering what would be the best method to attach the cable which would run from solar to plug in. What do I need to know when buying solar panels? The only thing I know so far is that solar trickle charger is NOT GOOD! How large would those panels need to be in order to recharge the two batteries? In case the electricity cable of the r-pod (what's the correct name for that cable?) would it also charge the TV's batteries? Any recommendations on flexible solar panels? My thinking behind this whole idea is that if the panels are on there all the time, battery could be charged constantly. But I have the feeling that constant charge is not good. Should the solar panel only be connected sporadically to recharge a lot? So many questions ![]() Thanks for reading.
GingerPod
Joined: 09 Jul 2014 Location: Pinehurst NC Online Status: Offline Posts: 67 |
Posted: 30 Jul 2014 at 9:17pm |
I'm not so sure I would want to mount the panels to the roof of my POD,flexible or not,but that's just me.
I like to park and look for the shadiest campsite I can find,then find a nice sunny spot out of the way to place the panels. But here is a excellent website that has great products and customer service.Probably would have all you would ever need and then some. https://www.renogy-store.com/default.asp |
FOUND OUR NEW-RETRO TEARDROP!!!
Inge
Posted: 30 Jul 2014 at 10:20pm |
That is a good point. I thought, I'd charge the batteries as well when I'm driving but I didn't think about parking in the shade. They should be charging while driving through the TV anyways.
RV-newbee :-) Thanks for the link! |
CharlieM
Posted: 31 Jul 2014 at 8:16am |
Inge,
If you plan to do much driving, instead of comfortably camped under a tree, your money might better be spent having the charge cable in your TV upgraded. Then you could get a much better charge to the battery on the road. |
Inge
Posted: 31 Jul 2014 at 1:49pm |
CharlieM: Do you think, if I ask my regular car repair guy, who seems to be very knowledgeable, should understand what to do when I tell him 'upgrade the charge cable'? Are there different options that I should know before I talk to him?
Any idea how much that could cost? Is it a complicated task to do? Thanks for this great suggestion!
WillThrill
Joined: 04 Jul 2014 Online Status: Offline Posts: 298 |
Posted: 31 Jul 2014 at 3:37pm |
Inge, it's not complicated to do at all. Any good mechanic should be able to do it in less than an hour.
The only real option is how big of a cable you want. Standard cable you can get from a home improvement store will work just fine. My local Lowe's sells 6 gauge 3 strand wire (2 is all you really need) for $1.06 per foot, and 25-30 feet should be more than enough. |
2014 Hood River 177 2005 GMC Envoy XL |
CharlieM
Posted: 31 Jul 2014 at 9:43pm |
The task is not complicated or difficult. I would shoot for #6 wire, but it's a bit hard to work with in tight quarters. A perfectly acceptable alternative is three #10 wires in parallel. Connect these between pin 4, called battery charge on the 7 pin connector, and the fuse or relay under the hood. The factory usually uses a #10 or #12 yellow wire for this, but that's not certain. Just tell your mechanic you want to beef up the trailer battery charging circuit in the TV.
Inge
Posted: 01 Aug 2014 at 12:58am |
Will do the charger cable upgrade asap! Good advice!
GingerPod's comment makes much sense to me and I'm looking now for panels that are not mounted to the pod. I'm wondering, do I need to buy Zamp solar panels because there is something preinstalled on the r-pod (zamp solar prewire kit) or can I go with something else like the Renogy 100W panel, which is half the price.
"Bommel" - r-pod 182 G " Franzi" - Toyota Tundra 2007 http://blog.picturingtheamericas.com |
Hayduke
Joined: 03 Apr 2012 Location: Salt Lake, UT Online Status: Offline Posts: 68 |
Posted: 01 Aug 2014 at 1:38am |
Not necessary to buy Zamp, other brands will work. Way overpriced in my opinion. Those Renogy panels seem like the best bang for your buck out there currently
2012 177 HRE
2017 Tacoma Double Cab |
CharlieM
Posted: 01 Aug 2014 at 6:50am |
I don't presently have a solar ready RPod so someone who
has should jump in and confirm or correct me if necessary. My
understanding is the only thing on the "solar ready" Pod is the wiring
and the connector, both of which are industry standard. The connectors are standard MC4 compatible. Any combination of compatible panel(s)/controller should be fine. The Renology panels are getting good reviews, but the Renology controller seems inadequate.
Check the thread http://rpod-owners.com/forum_posts.asp?TID=5017&KW=zamp&PID=48716&title=connecting-a-100-watt-solar-panel-to-zamp-port#48716 to get some ideas from other Podders |
Page 123> |
