List Your Mods:
 Post Reply Post Reply Page  <1 2425262728 79>
Budward View Drop Down
Post Options Post Options   Quote Budward Quote  Post ReplyReply Direct Link To This Post Topic: List Your Mods:
    Posted: 28 Jul 2014 at 7:51am
Cody91-  where'd you find that net?   Only ones I've been able to find are either only 4 ft wide or way too wide....
TIA!
2014 179
cody91 View Drop Down
Post Options Post Options   Quote cody91 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2014 at 8:40am
TIA!
Budward,
I had trouble finding a net at local suppliers too.  I finally found this place online called Organized Obie.  They make netting solutions for RVs.
Here's the link.
Good luck,
Cody91
GingerPod View Drop Down
Post Options Post Options   Quote GingerPod Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 11:20pm
I just finished adding a 2nd battery....
I used a Marine cutoff switch mounted directly to the Battery box.
I can now isolate the battery from the camper at anytime.,But retained a permanent connection to the Zamp port so I can charge from the Solar panel at any time regardless of cutoff switch position.
Also enables me to be plugged in to shore power any length of time without fear of over charging the batteries or boiling them to bits  Big smile
Plus I added a steel cable and lock to keep honest people honest....
FOUND OUR NEW-RETRO TEARDROP!!!
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2014 at 9:41pm
No worries about the converter overcharging, it is a proper 3-stage charger.  Also if those batteries are two 120 volt batts, you'll get more total amperage by always charging and using them together instead of one at a time.  Look up Peukert Effect for techie info.
Post Options Post Options   Quote GingerPod Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2014 at 10:50pm
Thanks for the heads up on the converter charger.
Yeah both batteries are hooked together for use. Together also for charging,by either Solar or Convertor and of course while driving down the  road.
Double the available amps,both are 12V,should keep good for days dry camping!
SuJoPodders View Drop Down
Post Options Post Options   Quote SuJoPodders Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2014 at 3:32pm
Latest update on our 177 mods.
Leaving in a day for a month long trip to Alaska.
Trying to make it as livable as possible.
Curb side rear shelf.
Street side rear shelf.
Adapted shower caddy.
Storage pockets moved from bathroom.
Storage pocket from shower.
24" AC/DC TV/DVD
View of TV from bed.
Mount attached to kitchen slide out.
Custom made Cribbage Table.
Mounting hardware.
jan demarinis View Drop Down
Post Options Post Options   Quote jan demarinis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2014 at 5:12pm
I like it! Nice work. Have a great trip.
2014 178 HRE
The Podyssey
2013 BMW X3 35i
Prodigy RF Brake Controller
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2014 at 8:08pm
ditto
Tbslants View Drop Down
Post Options Post Options   Quote Tbslants Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2014 at 2:01pm
Hi TriumphRider,
I recently purchased the 179 and have the same issue with the TV...the links for the mod would be greatly appreciated. Thanks!!
Tina
ShazG View Drop Down
Post Options Post Options   Quote ShazG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2014 at 2:20pm
ShazG
