Page <1 56789> |
Budward
Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
Topic: 179 Axle IssuesPosted: 31 Jul 2014 at 8:01am |
It may not have had the upward bend when purchased but it did when it left the axle factory!
I confirmed with Dexter that MY axle, which they looked up the specs by the serial number, was built with positive camber via the upward bend. As I said I have other trailers with Dexter Torflex axles and they do not have the negative camber issue. Of course neither trailer has ever been run with anywhere near axle capacity, both are 7,000 lbs rated with two 3,500 lb axles. Heaviest has probably been in the range of 5-6000 lbs loaded max.. Anyway- my replacement 5000 lb rated axle is due to arrive at the distributor today...I hope it is on time as a forecast 2 days of rain is on the way. Need to get this swapped ASAP as we head out soon on a multi week 10,000 mi+ trip! |
2014 179
wildfire305
Joined: 22 Jul 2014 Location: Erlanger, KY Online Status: Offline Posts: 85 |
Posted: 31 Jul 2014 at 7:51am |
I rarely have a water hookup. But our campgrounds usually have a filling place. The manufacturer doesn't say we shouldn't carry water, they just warn you that it's a significant amount of extra weight. I carry 5 gallons in the tank for toilet flushes and dishwasher while out on the road.
My axle had no upward bend on it when purchased. Strangely, when I pull it the camber straightens under the right circumstances. Never had this type of axle before, could it be the nature of the beast? |
2005 Dodge Durango 4.7 V8
OLD Tow Vehicle 2004 Honda Odyssey 2015 RP179 "73b" OLD 2005 Viking Saga 2480ST popup |
Budward
Posted: 31 Jul 2014 at 7:29am |
Yes the wheels have positive camber when unloaded. When loaded they should ideally have zero camber. If they have negative camber at rest the axle is bent or overloaded. The axles are made with an upward bow in the axle tube to create the positive camber. My axle on the rpod has no such bow now, it had it when new. I own multiple trailers with torsion axles and NONE of them except the rpod have negative camber. As for filling up at the campground- some campgrounds out west have NO water, it has to arrive with you. Water places no undue strain on an axle- unless the manufacturer under spec'd the axle. Proper engineering would require the axle rating exceeds the weight of the trailer with ALL tanks full. To do otherwise is poor design. FR cut it too close with a 3500 lb axle with a trailer that weighs right at that or over ready to go....add some road pounding and there goes the axle alignment. |
2014 179
lippy1979
Joined: 11 Feb 2014 Location: Indianapolis Online Status: Offline Posts: 2 |
Posted: 30 Jul 2014 at 9:42pm |
Its typical for torsion axels to behave in such a way. The wheels will canter out when unloaded and as you increase the load, they will canter farther in. I personally would never travel with a full tank of fresh water. Fill up at the campground or just buy 3 gallon containers. Water weighs A LOT and puts undue strain on the axel. Not to mention making it harder to control going down the road.
Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9066 |
Posted: 28 Jul 2014 at 9:58pm |
I believe my tires have always leaned in at the top. 15,000+ miles so far and the only oddity is the 2nd ring of tread from the inside, on both sides, is worn down more noticeably than the rest of the tire.
wildfire305
Posted: 27 Jul 2014 at 2:57pm |
Just bought my 2015 179 and I can confirm the appearance of the axle. As mine sits empty, it is toed out/camber in. I don't think this will be much of a problem for me as we will likely only put one to two thousand miles on it a year. The tires will age-out before they wear-out for me. BUT it still looks bad. Also some QC issues with mine - fortunately I am a plumber. My trap in the lav sink was leaking, low point drain caps needed teflon tape on the threads - one was leaking. Kitchen faucet aerator exploded when that burst of air hit it when I practiced draining the system - I should have opened it slower.
My windows will not slide smoothly. Thinking that excessive sealant is stuck in the track channel. I might try silicone lubricant - any thoughts? OOPS - don't want to hijack this thread, I'll do a search. |
fwunder
Posted: 24 Jul 2014 at 7:42pm |
I now have 10,000 miles on my 2014 178. 8,200 the last month. Never traveled with less than a full case of wine and full case of beer and dodged a few buffalo. No axle problems here!
kymooses
Joined: 01 Aug 2010 Location: Louisville, Ky Online Status: Offline Posts: 1807 |
Posted: 24 Jul 2014 at 7:10pm |
Yup, my 181g is the fattest Pod on the road. 4 seasons now with the Dexter axle and we've not had issue one out of it. I hate to see things like this happening to other Podders! ![]() |
Budward
Posted: 24 Jul 2014 at 6:23pm |
![]() I did mention on here the nearby strike that took out my fridge control board- and I wasn't even plugged into external power- the campground had none. Perfect example of EMP. Was sure glad I had on my tinfoil hat when that happened.. ![]() |
2014 179
Joined: 03 Apr 2011 Location: Mayville, WI Online Status: Offline Posts: 1447 |
Posted: 24 Jul 2014 at 6:08pm |
Bud if I ever camp near a 179 I will come and see if it is you. With all the things you share that are wrong with your pod, and the troubles you have had with other campers I would be afraid of camping to close due to lightening strikes or something.
Page <1 56789> |
