spacemonkey
Topic: I made an expensive mistake Posted: 24 Jul 2014 at 1:14pm |
Ok, so got my new converter yesterday and almost got it completely installed, but i ran into something was unsure of. The Old WFCO fuse board has a 30 amp fuse for my slde out motor, but i was noticing the new board says 20 amp fuse max. (see Pictures below)
Here is the new board. You will notice that in the center of the board it says max fuse rating 20 amp.
Here is the old board. In this pic you will notice the 30 amp fuse for my slideout motor. My question is how do i hook up the slideout motor to the new board? Do i have to use a 20 amp fuse? Is that sufficient for the slideout motor?
I also notice that on the old board there is a section for fuse 10 and 11 that says 30 amp for slideout only.
The new board only has a section that is labeled "recommended for low current circuits" is this where i am supposed to put the slideout motor 30 amp fuse.
Thanks for your help as im a little confused on this part.
Budward
Posted: 24 Jul 2014 at 1:26pm |
I'm not sure why PD included a new fuse board...if it was mine I'd just cable the new PD convertor to the existing WFCO fuse board, assuming it is good.
In fact I did exactly that in another camper I once owned.
2014 179
Cap-n-Cray
Posted: 24 Jul 2014 at 1:39pm |
There are a bunch of subtle differences. Can you call PD and ask them?
Cary
2014 RP-177
spacemonkey
Posted: 24 Jul 2014 at 1:48pm |
yeah, i suppose i can give them a call.
The new pd board has a button on it for the charge wizard that the old board did not have. There is a 4 wire harness that connects the the fuse board to the converter via a 4-pin header on both components. I suppose if i did not change out the fuse boards, the charge wizard would not work correctly!
spacemonkey
Posted: 24 Jul 2014 at 2:11pm |
just spoke to PD and they were actually of little help. The guy i spoke with didnt have a clue as to how to remedy the situation. He said that the pd board is defiantly 20 amp max fuse rating. I asked about using the WFCO fuse board and he told me that the charge wizard would not work correctly without the new board. So im kind of at a standstill of what to do at the moment.
How do i know what the amp rating on the slideout motor is? just curious if it actually draws more than 20 amps. Can just use a 20 amp fuse?
He actually suggested that If i need a 30 amp fuse that It may be a good idea to return the PD and get another WFCO
CharlieM
Here's my shot, remembering I never had a slide in my Pod:
First, did you order the 55 amp replacement for the WFCO 8955? I'm surprised at the 30A battery protection fuses.
My Camplite has a Schwintek slide and it is fused at 15A in the PD power panel. I don't know what slide FR is using, but the Schwintek is popular and common. It would help if you can find documentation on the slide, but sometimes that's difficult. Maybe a current owner can jump in and help.
A fuse should be sized to protect the wire, not the slide. The slide should be wired with #10 wire, maybe #12. #10 is usually protected by a 30A fuse; #12 by a 20A fuse. A smaller fuse will always protect a larger wire, e.g. a 20A fuse will protect a #12 or #10 wire. If you can determine the wire size connected to the slide terminal in the original installation that may give you a clue.
My guess, and hope, is FR wired with #10 for the slide and protected it with a 30A fuse. This will minimize voltage drop and is good. However, I suspect the slide never draws 30A. In the absence of any better info I would connect the slide to a position 3-12, for example 3,4, or 5 and not the low current slots. Fuse it with a 20A fuse. If you can accommodate the rest of your circuits without using slots 1-2 I would not use them. Try to maintain the original order, or at least the fuse sizing associated with the original functions, to make sure the wiring is adequately protected. I don't know what size wire was used on those 10 and 7.5 Amp circuits.
For your protection I'd carry a few 30 Amp fuses just in case the slide really needs more than 20A on occasion. For those short times the #12 wire will be OK. If by chance the wire is #10 you'll be fine forever.
This is a bit difficult by remote control and without a Pod at hand, but I think we've got it. That said, we know that no two Pods were built the same anyway. Keep us informed and don't hesitate to ask the next question.
CharlieM
Posted: 24 Jul 2014 at 2:16pm |
The new pd board has a button on it for the charge wizard that the old board did not have. There is a 4 wire harness that connects the the fuse board to the converter via a 4-pin header on both components. I suppose if i did not change out the fuse boards, the charge wizard would not work correctly! | This would tell me the Wizard need some control and/or sensors on the fuse board. Try to use it until you can't. I think the 20A fuse will probably run the slide.Unfortunately the response from the PD guy is typical. Never mind they advertise and sell this unit as a replacement for the WFCO. Unfortunate, but not surprising.
spacemonkey
Posted: 24 Jul 2014 at 2:36pm |
ok, i went and looked at the wire. It is in fact #10 wire going from the fuse board to the motor. I also looked at the motor. It had a sticker on the back that says 18 to 1 ratio, max oper 30 amp, 12VDC. It is made by venture mfg of dayton ohio
Oh, and yes the model PD i have is the 4655
Cap-n-Cray
Posted: 24 Jul 2014 at 2:39pm |
One way around the 30AMP fuse would be to use a relay. Have the 20AMP fuse power a 30AMP relay with a 30AMP inline fuse on the relay to power the slide out.
Just a thought...
Cary
2014 RP-177
CharlieM
Posted: 24 Jul 2014 at 2:41pm |
| Good news on the wire. I guess I'd start with a 20A fuse and be prepared to change to 30A in the field. The slide probably doesn't really draw 30 Amps except for a start up pulse or if it's jammed.
